12-13-2018
20:22
10:36
HeydyF
12-13-2018
20:22
10:36
HeydyF
Ok here it goes my versa was almost dead the other morning before I went to work so I plug it in to charge. Then i went and got other things done, came back to my versa hot as can be and not turning on. I dont know what happened or even how to fix it. I just want my fitbit versa back. Please help me figure it out
12-13-2018 20:34
12-13-2018 20:34
@jesther22 Let it cool down completely and then try long pressing the left button. If that does not work try pressing and holding the left and bottom right buttons for several seconds until Fitbit logo flashes.
12-13-2018 20:42
12-13-2018 20:42
I have done everything
12-13-2018 20:46
12-13-2018 20:46
@jesther22 Have you tried 3-button factory reset?
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
12-14-2018 01:59
12-14-2018 01:59
@Marrrmaduke, @jesther22 My take is that there is a problem with the battery!! I leave it to Marrrmaduke to guide you further, but if the unit is new you may be able to get a replacement via customer support.
12-14-2018 06:21
12-14-2018 06:21
I have literally tired everything you suggested and nothing worked. It is only a couple of months old so I might just end up getting another one since I really miss wearing it but thanks for trying to help me
12-14-2018 06:42
12-14-2018 06:42
I have the same problem. 3 days ago the my screen just went blank. I have tried everything suggested here but still nothing. My ap is showing the battery fully charged. What do I do??
12-14-2018 07:50
12-14-2018 07:50
@jesther22 I think your battery has gone dead, there is one year warranty on them (EU: 2yrs), so if that's the case and it is not due to f.e. water intrusion (that may not be covered?) I think you stand a fair chance on getting a new Versa free of charge!
https://www.fitbit.com/legal/returns-and-warranty
@billgillthat your app shows the battery is full doesn't mean anything: you need to check the date and time it has last sync'd (it says near the top-left corner of the Versa page on your mobile app), that was the last time the battery status was sent from the Versa to the app. Let the community know if your Versa is still syncing even when when the screen has gone blank/black! 🙂
12-14-2018 12:36
12-14-2018 12:36
@jesther22 I agree with @lenny4d. At this point I would recommend reaching out to Customer Support to guide you through the next steps. You might need a replacement.
12-14-2018 16:09
12-14-2018 16:09
It shows last synced 2 mins ago but the screen is still blank.
12-14-2018 16:45
12-14-2018 16:45
@billgill ok - that seems to suggest your watch is still syncing fine, just a black/blank screen. What happens if you put it in the charger (you may need to tap a bit on the watch too), do you see the charging symbol or just nothing, still completely blank?
Have you either changed the clockface or the firmware recently/3 days ago? If so (but only then) I suggest to select one of the Fitbit clockfaces from the mobile app and install that instead. As you may know there some compatability issues between new 3rd party clockfaces and old firmware/and the other way around.
If you haven't done anything (no installtions of any kind), and the screen stays dark also when you put it in the charger etc, then possibly something is broken with the screen. In that case it is customer support...
12-14-2018 17:31
12-14-2018 17:31
@billgill I agree with @lenny4d. Change the clockface to one of the Fitbit originals. If this does not help, try to perform 3-button factory reset. If this fails, please reach out to Customer Support:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer (some users mentioned 3 minutes), as long as it's needed for the vibration to appear.
12-14-2018 17:33
12-14-2018 17:33
When I put in in charger it is nothing only a blank screen. I have not changed the clock face or anything since I purchased it in May. Thanks for your help btw.
12-14-2018 17:34
12-14-2018 17:34
Thanks. The watch will vibrate when I do the 3 button reset but still nothing on the screen still blank
12-14-2018 17:46
12-14-2018 17:46
@billgill Thank you. This confirms that it is probably a hardware issue. Please contact Customer Support to guide you through the next steps.
11-23-2019 05:43
11-23-2019 05:43
Just yesterday my FirBit Versa stopped charging, has a blank/black screen & gets very hot if I attempt to charge it. I've tried letting it cool down several times, tried 2 & 3 button restarts (holding seconds, even minutes) and no luck. Of course I bought it in Sept 2018, so now it's just past the one-year warranty period. It's been working just fine, every day/night for 14 months & then without warning it just quits like that. Pretty expensive purchase for no more than 14 months of usage. Very disappointed & angry, for the cost & assume no recourse for this issue now. Anyone have any other suggestions / recommendations?
06-04-2020 10:18
06-04-2020 10:18
Same, I purchased mine in June 2018 and it suddenly stopped working. I am going to switch to Apple Watch. This is the 6th Fitbit that I have bought
06-21-2020 01:45
06-21-2020 01:45
I have had similar problems. I managed to get a replacement watch from Fitbit last time as my watch was in warranty but today the same thing has happened. Put the watch on to charge, it heated up in the charger so have taken it out and is now not responsive. Like you, really frustrated & now considering hanging brands.
06-22-2020 06:47 - edited 08-08-2020 06:44
@Diva66 I have already switched and I love my Apple watch. They are discounted on Amazon's official site for apple products. The only caveat is that you have to charge your apple watch everyday.
07-13-2020 21:16
07-13-2020 21:16
I’m having exactly the same issue. Battery full according to app, but after being hot after charging it, can’t get it to turn on. I seriously wonder if the hot Fitbit poses a fire hazard. It was really hot. I thought it was fried. I didn’t think to check the app to see if it was charged. Thanks for suggesting that.
