07-09-2018
05:39
04:37
JuanJoFitbit
07-09-2018
05:39
04:37
JuanJoFitbit
My versa died completely while I was out shopping 2 days ago, when I got back home I placed it on the charger and its been on it for 2 days and I has not charged at all. I have tried charging from computers, and different wall outlets. I'm very upset!
07-09-2018 05:56
07-09-2018 05:56
Have you tried restarting your Versa? Do it several times and see if that revives it. If it doesnt help try a factory reset. Ifnthatbdoesnt work you will need to contact Support (link in my signature ) Let us know how you go
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
10-29-2018 13:25
10-29-2018 13:25
Me too! Had less than 2 weeks! This isn't right!
10-29-2018 15:19
10-29-2018 15:19
I had the same problem never did charge. And also the Versa got hot, no longer would it charge. Not happ with Fitbit right now
10-30-2018 14:25
10-30-2018 14:25
11-02-2018 07:18
11-02-2018 07:18
11-20-2018 02:06
11-20-2018 02:06
Lol this helped me out.. I was about to start panicking .. My versa wouldn't charge but I let go of the buttons as soon as the logo displayed and it seems to be fine now. Thanks!
01-12-2019 11:46
01-12-2019 11:46
I've had mine for a little over a week and won't charge. The app says it's battery is at half, the watch itself say 0. I put it on the charger and noting. I've tried the reboot and all I get is 0%. Not real thrilled with fitbit at the moment.
01-31-2019 05:59
01-31-2019 05:59
And when all of that does not work???
Still dead? Put back in box and return?
05-02-2019 09:13
05-02-2019 09:13
Same thing has happened to me! I’ve tried all previously suggested steps and no joy, it’s completely dead
05-02-2019 13:22
05-02-2019 13:22
05-02-2019 14:17
05-02-2019 14:17
05-02-2019 14:33
05-02-2019 14:33
05-02-2019 15:00
05-02-2019 15:00
05-12-2019 16:27
05-12-2019 16:27
My Fitbit versa is doing the same thing and I don't think there's a warranty on it so will they still replace it?
05-13-2019 00:02
05-13-2019 00:02
07-29-2019 11:24
07-29-2019 11:24
I tried the hold down all 3 buttons thing but nothing came up. Any advise other than replacing it.
07-29-2019 12:06
07-29-2019 12:06
call and they will send you a new one. That's what I had to do.
07-30-2019 05:27
07-30-2019 05:27
01-03-2020 19:09
01-03-2020 19:09
You saved my watch!!! Thanks mine was doing the same thing and this worked!!!!!
