07-14-2020
12:27
13:01
07-14-2020
12:27
13:01
Hi! My Versa synced then about 10 minutes later screen was black. Battery was at about 60% when I synced it, I’ve tried to charge it (charged ok two days ago), also tried to factory reset but bktbjbf happens. Very frustrating as it’s only 5 months old.
Please help!
07-14-2020 13:05 - edited 05-06-2024 06:07
Hi there @SunsetRunner, welcome to the Community Forums. I'm sorry to hear that your Versa's screen won't turn on. Thanks for the steps you've tried so far in order to fix it, I'll be glad to help you with this.
In order for me to better assist you with this, please confirm that you've followed the steps below as described in the help articles:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with it so your watch may haven't had the chance to get fully charged. Therefore, it won't turn on. So, please try these recommendations:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer07-14-2020 13:32
07-14-2020 13:32
Hi Maria, thanks for the quick response. I’ve tried all of your suggestions with no luck. Fitbit is no longer syncing. It’s as if it’s entirely dead with a flat battery but that was at 60% before the screen went black. I couldn’t restart it or do a factory reset as no matter how long I press the two buttons or all three the Fitbit logo doesn’t come up. Charger seems ok, but nothing happens when I plug it in.
07-14-2020 15:22
07-14-2020 15:22
Weird cause mine did the same thing today... Tried different cables chargers and power sources.
07-14-2020 15:42
07-14-2020 15:42
Mine also shut off was almost fully charged now won’t turn on or light up on the charger 😞
07-14-2020 16:49
07-14-2020 16:49
I bought my Fitbit in late November, 2019 (8 months ago).
I’ve worn my Fitbit every day. I’ll admit I never set up much, but was keeping track of my steps, and heart rate.
A couple of days ago I realized I couldn’t see the time on my Fitbit. I’ve noticed before that when outside I couldn’t see the time but assumed that was normal. This time, I couldn’t see anything but a black screen. Oddly enough I could swipe and get the next screen. I thought maybe my battery was down. When I put the charger on last night, it showed about half charged. I charged it anyway, to 100%.
Today, when at Walmart (where it was purchased) I asked them about it, and was shocked to see my charge was down to 17%!!!
They had no idea what was wrong and told me to contact Fitbit directly.
Then, I saw my weekly report from last week and evidently my problems started earlier than I thought! It isn’t showing any walking or anything at all during the last 10 days or so!
Help! What is wrong with my Fitbit?
Sent from my iPad
07-14-2020 17:46
07-14-2020 17:46
This is also happening to me. It randomly turned off last night and won't turn back on no matter what I try. I have done everything up to the Factory Reset, which didn't work either. I am pretty upset, as I just purchased this a little over a year ago. I even found the receipt (which is a big thing for me)! My Fitbit is really helping me stay motivated while at home and I'd be really sad if it won't turn back on. I understand that y'all must be through the roof with tons of messages, but I'd really love for my Fitbit to work again.
Thanks,
Liz
07-14-2020 20:11
07-14-2020 20:11
Best Answer07-14-2020 20:21
07-14-2020 20:21
Thank you as my watch is doing the same. In my app it looks as if there is a clock face trying to download but since my Versa cannot turn on, I cannot pause, cancel nor factory reset. I feel as if something is going on as I currently have it plugged into my Laptop and the laptop keeps making the "connection" sound but than "removed connection" sounds right after. So unsure if it is the battery or this clock face app.
Best Answer07-17-2020 04:33 - edited 09-30-2023 07:55
Hi there @SunsetRunner, thanks for getting back. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual. We hope your issue is solved soon.
Hi @Danr1987, @Suz778, and @lizrock, welcome on board. I appreciate the details provided in your post about your Versa smartwatches' behavior. I've seen that you contacted our Support Team after posting here and they helped you with this matter. If you have any questions about the resolution of your case, feel free to contacted them back for further explanation or you can check our warranty policies here for a better understanding of the information that they provided to you.
Hey @Martini1964 and @Suz778. Thanks for the details shared in your post about what happened to your Versa smartwatches. I totally understand where your concern is coming from. I'm here to help you two.
To better assist you with this matter, would you mind try the steps I've shared here or confirm that you've followed them as described?
