08-05-2020
11:59
11:51
08-05-2020
11:59
11:51
My versa is not switching on... when ever I keep it on charge it's getting heated.
08-06-2020 11:55 - edited 10-03-2023 17:22
Hi there @ErvaHarish, welcome to the Community Forums. Thanks for the details provided in your post about your Versa's recent behavior. I'll be glad to help you with this.
As per the description of your post, it seems that your Versa is not having a good connection with the charger, therefore, it won't properly charge. Said that, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
