11-17-2020
11:00
12:20
11-17-2020
11:00
12:20
My versa has completely stopped working. I charged it this morning and their was no issues. This afternoon the touch screen stopped working and it has now gone completely blank. I have tried the restart and nothing. Not even charging now. So frustrating.
11-17-2020 12:25 - edited 06-06-2024 12:09
Hi there @Emmafergie, welcome to the Community Forums. I'm sorry to hear that your Versa stop working this afternoon, I understand where your concern is coming from and why you're feeling frustrated. Thanks for trying to fix the issue prior to posting here, I'll be glad to continue helping you.
When you performed the restart on your watch, did you feel a vibration? If you din't, please try the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
11-17-2020 15:02 - edited 11-18-2020 01:06
Thank you for replying @MarreFitbit. I have tried everything including the factory reset and its still completely dead. There's no vibrations and the logo didn't come on at all.
11-19-2020 06:40 - edited 11-08-2023 14:55
Hi there @Emmafergie, thanks for the update.
I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
We hope your issue is solved soon.
