06-29-2021
07:06
09:06
06-29-2021
07:06
09:06
I have one of the first Versas. Two days ago out of the blue it shut off and will only turn back on if I put it on the charger. The battery was at 86% when it shut off the first time. Since then it has shut off several times. I have tried the factory reset and made sure that it is updated. Sometimes it will even shut off when it is still on the charger. Any suggestions or do I just need to replace it?
07-15-2021 08:32
07-15-2021 08:32
I also have the same issue with my versa!
