09-23-2021
09:38
09:48
09-23-2021
09:38
09:48
Hi my versa has died and won’t charge or wake up. Tried advice from troubleshooting guides but still nothing. It was working fine without issue then nothing
09-23-2021 09:51
09-23-2021 09:51
Hi there, @DonKirk14. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
09-23-2021 09:51
09-23-2021 09:51
Hope that helps.
09-23-2021 11:43
09-23-2021 11:43
Hi tried all of the above and after having on charge for 2hrs still no battery life.
09-23-2021 12:17 - edited 06-08-2024 12:01
@DonKirk14 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
