Versa won't turn on or charge
ANSWERED
I have a Versa. I was holding a charge for a couple of days, but also was pretty good about always keeping it charged and not letting it die. A couple of weeks ago it did just that, it died. What to do?
1 BEST ANSWER
Accepted Solutions
Hi there, @Kmoto. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
If the restart doesn't work and the Versa does not vibrate while trying to perform the restart, I'd suggest trying the below steps:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
1 REPLY 1
