05-24-2020
08:54
04:29
JuanJoFitbit
05-24-2020
08:54
04:29
JuanJoFitbit
Hello
I have a Fitbit Versa that I did not use for a while then when I tried to charge it, did not work I got black screen and sometime Fitbit logo shows up. What Can I do to solve it? I tried to charge it i diferent source and did not work. I tries to reset it pressing the left and right below button and did not work neither.
I bought it just 1.5 years ago.
Regards
06-04-2020 04:28
06-04-2020 04:28
Hi @Karlota, it's great to see you in our Fitbit Community! I'd like to follow up and help you with your Fitbit Versa since it's not turning on or taking a charge. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
Keep me posted on the outcome.
06-11-2020 11:36
06-11-2020 11:36
Hello JuanJo
Thanks for your reply
I just tried what you suggested and these are the results:
- Once I pressed the 3 buttons, Fitbit logo dissapeared
- once logo dissapeared I released the bottom right button
- watch never vibrates I keep pressed the buttons for a while and after release all the buttons it did not reset
