07-08-2020
19:47
06:50
07-08-2020
19:47
06:50
Versa will not turn on unless its on the charger.. If I take it off the charger it just won't turn on.. I have tried the factory reset .. three button hold and the single hold on the left button but no luck.. When its on the charger the fit bit logo comes on and it goes to my clock face then goes black.. What are my options pls?
07-09-2020 06:54 - edited 06-08-2024 11:25
Hi there @Rainman8, welcome to the Community Forums. Thanks for the details provided about your Versa's behavior and for your time and efforts in fixing it prior to posting here. I'll be glad to help you with this.
As per the description of your post it seems that the battery of your Fitbit may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
