12-22-2019
16:25
07:06
JuanJoFitbit
12-22-2019
16:25
07:06
JuanJoFitbit
I have a Versa and it was fully charged at 100%. I turned it off. When I tried to start it up again, the back button did not work. I tried pressing the back button and the bottom button, and after holding it for 15 seconds it turned on. However, it went from being fully charged at 100% to 89%. I'm not sure why the back button is not working to turning on the device and why its losing a charge by being turned off. I purchased the Versa in May.
12-23-2019 07:05
12-23-2019 07:05
@20VicBar10, welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it didn't turn on when you tried to press the buttons.
Please try cleaning around the buttons by using a toothpick in order to remove any dust that may be affecting the functionality of the buttons.
If the issue persists, please put the watch on the charger and let me know if it vibrates.
Looking forward to your response.
12-23-2019 08:21
12-23-2019 08:21
12-25-2019 08:13
12-25-2019 08:13
@20VicBar10, I'm sorry for the late response. However, I appreciate the time spent trying the recommended troubleshooting step.
I'd like you to try one more workaround that has been helpful in order to revive your Versa. Try the steps that are listed in this help article. This article contains the restart process but you can skip it and proceed with the rest. Finally, charge your watch for 2-3 hours and see if the issue gets fixed.
Keep me posted on the outcome.
12-27-2019 14:05
12-27-2019 14:05
01-01-2020 08:26
01-01-2020 08:26
@20VicBar10, I apologize for the delayed response. I'm glad to hear that the battery is not draining fast.
Since the back button is still unable to turn the device unless you press 2 buttons, I'd like you to try a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Please sync your watch before this in order to avoid losing current data.
After this, monitor your Versa and see if the back button turns on the display properly.
Let me know how it goes.
01-03-2020 12:03
01-03-2020 12:03
05-10-2020 13:17
05-10-2020 13:17
This is exactly what is happening to me. I am not sure if it is part of the update or what. As you describe it, I reset to factory default and still I have to press the back button together with the 2 buttons to turn it on.
05-10-2020 14:29
05-10-2020 14:29
I have the same issue and nothing is working.
I tried factory reset, cleaning the fitbit, charging the fitbit for an hr, now its not turning on at all.
05-16-2020 05:06
05-16-2020 05:06
