06-15-2018
00:36
04:21
AlejandraFitbit
06-15-2018
00:36
04:21
AlejandraFitbit
Last night I left it charging because the app was showing battery low and today I am trying to turn it on and nothing is happening. Anybody is facing the same problem?
Please help!
11-29-2018 18:34
11-29-2018 18:34
@Sorokjo I would reach out to customer support.
11-30-2018 00:21
11-30-2018 00:21
I have my Versa for like 4 months and I am experiencing the same issues. I love it but if I can’t this resolved. I am just going to but the Apple Watch and return my Versa
12-10-2018 07:45
12-10-2018 07:45
So I have my versa for less than 12 month and already got it replaced twice for the same issue 😫
12-10-2018 17:03
12-10-2018 17:03
Right I don’t know if this is the solution to your problems or not but it worked for me. I had the same problem as you are all having or something similar. It started on Sunday, I noticed that I had got an Email fromFitbit to say that my Fitbit Versa was low on charge, which I found strange because it was charged the day before to full capacity and I thought that didn’t last long. So when I woke up this morning the watch was as dead as a dodo. Black screen, no life in it at all. I pressed the left side button hoping that it had gone to sleep but still no response. So I put on the charger and usually it lights up notifying me it is charging but again not a sign that it was taking a charge. So I left it on the charge for a half an hour and when I came back to it again there was no life in it. So I thought, the battery must have depleted itself and it was going to take a long time to charge.So I went out for a walk and left it on the charge and I forgot about it. So it was on the charge for about 11 hours.....more than enough time to be working or to show signs of life.
Sadly, no. I said to myself this is useless I have only this device a month and here it is useless, not working. I then came to this Forum to see page after page of people complaint about their Fitbit not working and sending them back and getting refurbished ones and new ones and I read that if you hold down the buttons (all three buttons) for 10 seconds that will solve it. I did that and it didn’t work and I thought what if I hold the three buttons down a much longer time. So I did that, I held the three buttons down for about three minutes and suddeningly, it flashed up the Fitbit logo and it dimmed and then came back on and stayed on for over a minute. I thought it’s either bust or this appears to be resetting itself. And suddeningly the time came up and everything is working. It’s as if it has woken up from a deep deep sleep.
so I don’t if it is a Solution but it’s worth trying, it can do no harm, it worked for me. Hold down all three buttons for about three minutes or until the Fitbit Versa Logo comes up and then let go.
12-10-2018 17:37 - edited 12-10-2018 17:38
@Lordsnooty yes, you're right. That's why I always recommend playing with times when performing 3-button factory reset. I find it extremely tricky to perform. Nevertheless, please keep us posted how your battery behaves after the reset, or reboot in this case.
12-10-2018 17:54
12-10-2018 17:54
Will do........what I have quickly just noticed is the clock is slow by about 10 minutes here in the UK but I can’t fix it now as it is very late here at about 1.50am in the morning but if I get a chance tomorrow I will adjust that and hopefully that will be it sorted (fingers crossed)
12-10-2018 18:22
12-10-2018 18:22
Mine does the same thing every time I charge it. When this happens I put it back on the charger until it turns on again. So basically I have to charge it twice every time the battery is low
12-11-2018 21:00
12-11-2018 21:00
@Lordsnooty thank you! 😊😊😊
12-12-2018 17:29
12-12-2018 17:29
Thank you soooo much! Holding down those 2 buttons worked! I was freaking out because my versa would not turn on! Thank you!!!!
12-12-2018 17:44
12-12-2018 17:44
No Problem. Remember I was in the same position as you, with what appeared to be a totally Dead Fitbit. Plus all Fitbit where offering was a possible remedy to hold down the buttons for 10 seconds. I did that and it didn't work.....nothing happened. I then left it on the charger for most of the day and still, it didn't work. Then I saw all these messages that basically said the same thing that Fitbit Versas where useless and people wanted to send them back. I thought surely that can't be right has Fitbit put out a dud, a rubbish product....surely not and then I thought what if I held all three buttons down for a couple of minutes, just like I do with my iPad when it freezes and does some stupid things.
I just wish Fitbit would make this suggestion of holding down all three buttons for a couple of minutes common knowledge.....maybe they wouldn't get all these Fitbit Versa's back to be replaced....just a suggestion
12-12-2018 18:13
12-12-2018 18:13
I got my problem resolved after exhausting all troubleshooting topics Fitbit concluded that I was still under warranty so the mailed me a new one and it is working fine as of now. Thank you Fitbit for the excellent customer service.
12-31-2018 19:20
12-31-2018 19:20
I’m having the same problem. My Fitbit Watch been dead for a day now . I’m still trying to figure out how’d it happened and how I could fix it.
12-31-2018 19:36
12-31-2018 19:36
Hi there. First of all is the Versa fully charged. If it is try this hold the THREE BUTTONS in for a couple minutes (yes not 10 seconds as Fitbit says and not two buttons but 3 buttons) . With me the Fitbit logo came up and I let go of the buttons and everything came back to normal. If that doesn’t work then I would suggest that contact Fitbit and tell them what has happened and I’m sure they will send you another one (I don’t if it will be new or refurbished but it will work). Try my solution first and see if that works and if so let us know
Happy New Year
12-31-2018 20:05
12-31-2018 20:05
01-09-2019 06:33
01-09-2019 06:33
I charged mine overnight and have tried all of the above options for my Versa. It will not turn on. I had the same thing happen to my Charge and I gave up on that. Hoping the Versa would be better. I don’t think I’ll repurchase anything from Fitbit. I’ve only had my Versa for a couple months.
01-09-2019 06:37
01-09-2019 06:37
01-23-2019 18:49
01-23-2019 18:49
Yippee! My DoDo Bird woke up. Thank you for the tip.
01-28-2019 05:04
01-28-2019 05:04
Did you ever get your versa to work?
If you did how did you do it because mine is doing the exact same thing.
01-28-2019 05:16
01-28-2019 05:16
01-30-2019 20:53 - edited 01-30-2019 20:54
Hi,
I’ve had my Fitbit Versa for a month now and it just died and won’t come back on. I have tried restarting it. The logo flashes then the screen just goes gray and it vibrates but doesn’t come back on. Can you please help?
