06-15-2018
00:36
04:21
AlejandraFitbit
06-15-2018
00:36
04:21
AlejandraFitbit
Last night I left it charging because the app was showing battery low and today I am trying to turn it on and nothing is happening. Anybody is facing the same problem?
Please help!
01-30-2019 20:59
01-30-2019 20:59
01-30-2019 22:06
01-30-2019 22:06
@SunsetRunner Welcome to the forum. Have you tried 3-button factory reset?
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're successful with factory reset, please remember to remove Versa from your Fitbit account (in your Fitbit mobile app) and Paired Devices list in your phone Bluetooth settings as you will have to set it up again (add as a new device).
01-30-2019 23:51
01-30-2019 23:51
Hi Mandy, I'm experiencing the same problem as yours. Were you able to solve this problem?
01-31-2019 03:12
01-31-2019 03:12
Have you tried mine and Marmadukes solution which is this:-
in my case it took longer than 3 minutes.
It it may work or you may have to talk to Fitbit about a replacement. I have had other fitbits in the past and problems have happened and I have found Fitbit Customer Service very understanding and have replaced any defective units without any hassle. I know that this shouldn’t happen but life and gadgets have flaws and nothing is perfect.....nothing at all. So try the above solution and if that doesn’t work (and remember to fully charge it) contact Customer Services and get a replacement.
01-31-2019 06:41
01-31-2019 06:41
02-06-2019 11:26
02-06-2019 11:26
Held 3 buttons down for 5 minutes and still won’t turn on. It’s only 7 months old. Might switch to another device
02-06-2019 14:04
02-06-2019 14:04
@808sue you should reach out to Customer Support as this seems to be a hardware issue.
02-06-2019 19:06
02-06-2019 19:06
02-09-2019 08:48
02-09-2019 08:48
My Versa is having the exact same problems. Woke up to it completely off which is odd because I just charged it yesterday. I also do not have any watch face from any third party. I do not know what to do. I have tried everything to turn it on. Help please!!!
02-09-2019 09:06
02-09-2019 09:06
02-09-2019 11:01
02-09-2019 11:01
The main thing is NOT to PANIC
The same thing happened to me after I had charged.....it was completely dead....nothing happened. I thought my goodness that didn't last long, what a bundle of TRASH. I have had many fitbitsand nothing like this had happened to me. I held all the buttons down for roughly about a minute and nothing happened. I went to this Forum and I had seen what people where saying that I should hold the buttons down for a complete minute...but that didn't work still...... no screen. So I left it for about an hour and did what they said and held all the three buttons down for a minute but still nothing. So I left it for a day and I thought maybe it had been overcharged maybe it will have run down a little to let it work. I tried turning it and again it didn't work. I was ready to throw it in the bin or write to Fitbit and tell what a load of junk they had. So desperate I decided to hold the three buttons in but this time I thought I will hold them in for much longer....what had I loose, sure it was going into the bin or being sent back to them and asking for my money back.
So I did this:-
It worked, it came back from a deep deep sleep and has been working really fine.
If this doesn't work for you then phone Fitbit customer Service and tell them what you have done to fix it and I am sure you will get a replacement ....their customer Service is second to none
best of Luck and let me know how you get on
PS try leaving the Fitbit alone for a day and then try the above method
02-16-2019 14:26
02-16-2019 14:26
Hiya, please can support contact me. My Fitbit versa has got the black screen and won’t restart. I have tried to complete restart and this doesn’t work. It doesn’t show charging once in the cradle to charge. It’s pickinh something up on the ap as it’s stoll counting steps etc.
02-16-2019 14:51
02-16-2019 14:51
Hi, I would advice you to contact Customer Support ASAP. you have to do that yourself. Either call or email them about your issues.
02-16-2019 18:13 - edited 02-16-2019 18:14
Hi @Rubyannboris I will flag your post for a moderators attention. They should be able to help you.
Helen | Western Australia
02-17-2019 06:25
02-17-2019 06:25
Lights on back of my Versa quit flashing. Did the 3 button 10 second reset.
Now one flashes intermittently. It the small light of the four.
02-17-2019 12:30
02-17-2019 12:30
I don't mean to be rude or cheeky but have you not read numerous previous messages in this thread about the 10 sec reset?
Obviously NOT.
If you had taken the time to read this thread you would have seen that in general 10 secs doesn't work whereas it's a combination of at least 3 minutes to 6 minutes and having the versa fully charged and left for 24 hrs. I would suggest you read the other comments in this thread
02-17-2019 13:06
02-17-2019 13:06
02-17-2019 18:21
02-17-2019 18:21
So Jim is it working now?
if it is that is good, maybe you can post how you got it to work again so that others can learn how it is done.
i wish Fitbit where monitoring this thread and would see that the 10 sec rule doesn’t really work and they should make the time a lot longer.
anyway all’s well that ends well
02-17-2019 18:36
02-17-2019 18:36
02-17-2019 19:39
02-17-2019 19:39
Yes you have to reset it as if it is a new Versa (which is a real pain) but it will now work and give you sleep readings and the correct time.
