06-15-2018
00:36
04:21
AlejandraFitbit
06-15-2018
00:36
04:21
AlejandraFitbit
Last night I left it charging because the app was showing battery low and today I am trying to turn it on and nothing is happening. Anybody is facing the same problem?
Please help!
02-22-2019 06:04
02-22-2019 06:04
I have tried all the things recommended on these forums. It won't charge, won't turn on, won't do anything. I have tried other oulets, other chargers, nothing works. Should I just return it?
02-22-2019 07:26
02-22-2019 07:26
02-22-2019 08:52
02-22-2019 08:52
02-22-2019 09:50
02-22-2019 09:50
02-22-2019 09:55
02-22-2019 09:55
Didn't work for me.
02-23-2019 01:19
02-23-2019 01:19
Contact Customer Services and rell them what you have done to try to fix it and they should send you a replacement
02-24-2019
06:25
05:59
JuanJoFitbit
02-24-2019
06:25
05:59
JuanJoFitbit
Did that, would not turn on, uninstalled the app reinstalled , set the versa back to factory like it came, will not turn on. The Fitbit logo comes on and turns off, if I use left button to turn on clock, will not turn the actual versa on.
What number did you call to get action on your problem
Moderator edit: merged reply
02-24-2019
06:36
05:58
JuanJoFitbit
02-24-2019
06:36
05:58
JuanJoFitbit
I clicked on help center and had live chat. They are sending a new one.
Best Regards,
Moderator edit: removed personal info
Referrals are the best compliment!
02-24-2019 07:06
02-24-2019 07:06
Before you contact customer services have tried this solution? :-
You may need to attempt the reset a few times to find the optimal times. Try holding the buttons longer, as long as it's needed for the vibration to appear.
in my case it took longer than 3 minutes.
If the above doesn't work then you will have to talk to Fitbit about a replacement. I have had other fitbits in the past and problems have happened and I have found Fitbit Customer Service very understanding and have replaced any defective units without any hassle. I know that this shouldn’t happen but life and gadgets have flaws and nothing is perfect.....nothing at all. So try the above solution and if that doesn’t work (and remember to fully charge it) contact Customer Services and get a replacement.
02-24-2019
07:16
05:57
JuanJoFitbit
02-24-2019
07:16
05:57
JuanJoFitbit
It won't charge or turn on, replacement is on the way.
877-623-4997
02-24-2019 08:17
02-24-2019 08:17
02-25-2019 10:08
02-25-2019 10:08
I have the same problem. Charged it overnight and it is still black - no sign of life and not showing that it is charging when in holder. Tried pressing all 3 buttons and it appears to be trying to switch on but then just died again. Any solutions? Had nothing to problems with the device since I got it last year.
02-25-2019 13:05
02-25-2019 13:05
02-25-2019 13:24
02-25-2019 13:24
Try resting it for a day or so. Then try holding the three buttons down for about 5 mins or the Fitbit logo comes on. If that doesn't work then get in touch with Customer services and tell what you have done and they will send you a replacement unit.
Let us know how you get on
02-26-2019 12:32
02-26-2019 12:32
Thanks - still no joy although think it might be a screen issue now as it was synching and the alarm went off this morning. Just can't see anything other than a black screen. Going to contact Fitbit to ask for a replacement.
02-28-2019 05:31
02-28-2019 05:31
Total joke experienced
@eyadqarooni wrote:Last night I left it charging because the app was showing battery low and today I am trying to turn it on and nothing is happening. Anybody is facing the same problem?
Please help!
the same thing
02-28-2019 05:56
02-28-2019 05:56
@808sue @medavis68 @Jendivico @katiemacny I'm sorry for the late response. However, I'm so glad to hear that you were sent a replacement unit. Thank you for posting the update here.
@Jimshan I would like to follow up and would like to know if the issue persists or if your Versa is working properly now.
@Rubyannboris I'm sorry to hear that your Fitbit Versa won't turn on. I was able to get in touch with our Support team and was told that they contacted you via email. Was a solution provided?
@Akint @NellyG @Lordsnooty Thank you so much for your help guys!
@Alisoncm I'm sorry to hear that your Fitbit Versa is not turning on. I would like to follow up and would like to know if you contacted our Support team. If so, was a solution provided?
@MidnightAmbtion Welcome to our Fitbit Community! I'm also sorry to hear that your Versa is not turning on either. If you haven't done so, please restart your tracker as described in this help article. After this, clean the contacts of your tracker and charger with a cotton swab. Finally, charge your tracker for 3 hours and see if it comes back to life or if the issue persists, let me know and I'll be happy to assist you accordingly.
I'll be around if any questions arise guys!
02-28-2019 06:03
02-28-2019 06:03
I have contacted the support team and awaiting a response. The device is still failing to power up. There is no longer a green light on back either. Really disappointing.
02-28-2019 06:11
02-28-2019 06:11
MidnightAmbition personally this happened to me when I left my Versa overnight to charge. I don't think that's a good idea, it seemed to overcharge it. I did what others told me and charged it for another 3 hrs but again it didn't work. So I left it for over 24 hrs and then tried holding down the 3 buttons on Versa for over 3 minutes or more or until the Fitbit Logo came up
If this works you will have to reinstall your Versa on your PC profile. Hope this helps and if not contact Customer Services and seek a replacement
03-04-2019 07:55
03-04-2019 07:55
@Alisoncm I'm glad to hear that you've contacted our Support team. You are in good hands now and they'll be happy to provide a solution.
@Lordsnooty Thank you for sharing your experience and the steps you followed. Please don't hesitate to get back if you need further assistance and I'll be happy to assist you.
See you guys around!
