06-15-2018
00:36
04:21
AlejandraFitbit
06-15-2018
00:36
04:21
AlejandraFitbit
Last night I left it charging because the app was showing battery low and today I am trying to turn it on and nothing is happening. Anybody is facing the same problem?
Please help!
04-08-2019 10:31
04-08-2019 10:31
Do you have the number for Fitbit?
04-08-2019 12:14
04-08-2019 12:14
04-08-2019 14:41
04-08-2019 14:41
04-08-2019 15:10
04-08-2019 15:10
Chat with Fitbit customer services. You will be advised on what to do. If it still doesn't work, a replacement may be sent to you at no cost. Fitbit customer care officers are very friendly and ready to assist
04-09-2019 03:08
04-09-2019 03:08
Downloaded bitmoji clock face within two hours my watch stopped working. The screen is black and won't turn on or reset..
04-18-2019 12:29
04-18-2019 12:29
I am having this same issue, I left my Fitbit verse on the charger overnight and in the morning it was very hot and did not turn on but the green lights in the back will flash from time to time??? I tried the holding in the buttons I never had this issue
04-18-2019 15:01
04-18-2019 15:01
I would suggest that you leave it for a full day. Then hold the three buttons down until the Fitbit logo comes on. Hold them down for at least 3 minutes, if not more than that....maybe up to 5 minutes. If that doesn't work then contact Fitbit Customer Services and they will send you a new one
Best of luck
04-26-2019 12:47
04-26-2019 12:47
I am having the same issue.
I have tried the restart procedure as well as holding down all 3 buttons to no avail. I had it charged all night. Not sure what else to do. Please share any solutions you may have.
Thanks in advance.
04-26-2019 14:00
04-26-2019 14:00
Did you let it rest for a Day before doing the 3 button solution? As I have said many times before in this thread this same problem happened to me and the way I sorted it out for myself was I let it rest for a full whole day and then tried the three button method. Now it took three or four minutes before it came to life but it did come back to life. Don't worry if that doesn't work then contact Fitbit Customer Service and they will send you a new one, Try resting it
04-27-2019 02:13
04-27-2019 02:13
04-27-2019 13:33
04-27-2019 13:33
My versa wont turn on. Its buzzing when I pull it into the charger. My phone says its syncing but the green light on the back is not flashing. I've tried the restart method. It's not working. I'm highly upset I need this. This is my alarms
04-27-2019 14:49
04-27-2019 14:49
This sounds different from the problem I had. I didn't have any buzzing out of mine. The main thing is don't worry and don't get upset. Phone Fitbit Customer Services and explain what is wrong....that you are getting a buzzing sound out of it when you put it on the charger. I would say they will send you a replacement. Best of luck and let us know how you get on
04-28-2019 03:17
04-28-2019 03:17
I am having a very similar problem. I was swimming in the sea as usual and when I came out my Versa was unresponsive. I’ve tried pressing all the buttons and holding them down but nothing happened. I tried charging it but the screen didn’t light up and it just became very warm. Please help
04-28-2019 07:16
04-28-2019 07:16
I tried that but it didn’t work. Do u have any other solutions?
04-28-2019
09:37
07:08
JuanJoFitbit
04-28-2019
09:37
07:08
JuanJoFitbit
Sorry, what did you try? What is happening to your Fitbit Versa? What happened when it stopped responding? Is there any sign of life coming from it?
This isn't exactly the same problem that thread is dealing with in that you were swimming when it stopped responding....maybe water got into it. I would suggest that you contact Customer Services and tell them what happened and what you were doing when it stopped working. Have you tried drying it out?
Moderator edit: merged reply
04-28-2019 09:50
04-28-2019 09:50
04-28-2019 12:53
04-28-2019 12:53
Kikijanay as I said to you, it was a different problem from what this thread was dealing with. It sounded like it was faulty whereas mine wasn't faulty. Good that Customer Service sorted you out (I knew they would as they are probably one of the best companies for customer service....in fact they remind me of what Apple used to be like but unfortunately are no more). Thanks again for coming back and letting us know what happened.
05-02-2019 11:51
05-02-2019 11:51
@MidnightAmbtion @katiemacny @Kikijanay @dtarvin @Aslate @Jfaust1278 @Kymmie814 @Adelle66 Welcome to the Fitbit Community for the members! It's great to have you here! Thank you all for your posts and the troubleshoots you have tried and sorry for the late reply.
@MidnightAmbtion @katiemacny @Kikijanay happy to hear that your devices were replaced.
@dtarvin @Kymmie814 thank you for restarting and charging your device. Please let our Support team know so they can further assist you. I noticed that you already have a ticket with them so I would like to know if they were able to help you?
@Aslate please try changing the clock face and charge it.
@Jfaust1278 @Adelle66 same for you please let our Support team know so they can help you. I could see that @Jfaust1278 already has a ticket but @Adelle66 so I created one for the latter. You will get an email from the Support team.
@MattyIce same as @Lordsnooty I would like to know what it is happening and what have you done?
@VijayBagga @Lordsnooty thank you so much for your help in this thread.
Let me know how it goes.
05-22-2019 09:40
05-22-2019 09:40
Thank you SO much for your post! I am on vacation and my Fitbit was working fine last night when I put it on to charge. Then it seemed dead this morning. I was just going to go out and buy a Timex to use until I got home. I decided just to check online before I left. I did exactly as you suggested and now it’s working fine!
05-22-2019 15:42
05-22-2019 15:42
My verse is also dead and won’t turn back on at all
