01-01-2019 14:23
01-01-2019 14:23
my versa went flat yesterday and now won't turn on.
I have tried charging it on different power adapters, and hard restting it won't even work.
The screen stays completely black.
I have made sure it is connecting with the charging pins correctly and still nothing.
I only got the versa 4 months ago.
Best Answer01-01-2019 19:24
01-01-2019 19:24
@NicM86 When was the last sync? Is it screen that is dead or the watch (does it still sync, connects when you open fitbit mobile app, do sensor lights blink?)
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're successful with factory reset, please remember to remove Versa from your Fitbit account (in your Fitbit mobile app) and Paired Devices list in your phone Bluetooth settings as you will have to set it up again (add as a new device).
