09-15-2020 04:34
09-15-2020 04:34
@AdryantoS If your Fitbit app has the face available, you should be able to install it.
However, I’m in the USA and it won’t install. It keeps giving me an error and I’ve tried everything. I’m wondering if too many people are trying to download it.
I can install other clock faces without an issue.
09-15-2020 05:30
09-15-2020 05:30
I'm having the same problem. I have a Versa, not Versa 2. Is it confirmed that the SPO2 clock works on that older model? After trying to install it, it now appears on my row of 5 saved clock face icons, but with a "+" symbol, not yet installed. Selecting it goes to the installing screen and never completes. No problem installing or switching to another clock face.
09-15-2020 05:38
09-15-2020 05:38
I can't find my saved clock faces after installing SPO2, but it did show oxygen level after sleeping and resetting Versa 2
Best Answer09-15-2020 09:48 - edited 09-15-2020 09:52
@bugstomper Yep, it sounds like we are having the same issue. Very frustrating! And I've tried all of the following:
Nothing works to install this face, unfortunately. 😞
09-15-2020 14:23 - edited 09-15-2020 14:24
It has changed overnight. Instead of a plus, the icon in the bar of installed faces now has a down arrow. When I tap it, it now tells me that the face is not available in my region yet. I'm in New Zealand. That doesn't explain why you can't install it in the US, but it does show that something changed, so maybe you will get a better result now.
09-15-2020 18:06
09-15-2020 18:06
I search it at website and find this https://gallery.fitbit.com/details/fadb02f3-5d1b-4588-a05c-e6a9db74bf7a and click open in the app. Tried to download it but it just showing a bar
Best Answer09-15-2020 18:12
09-15-2020 18:12
Just got an update to fitbit app, and now it showed it not available at my region... **ahem**, we need that clock face during this pandemic time
10-13-2020 19:48
10-13-2020 19:48
I have the original Versa model and the SPO2 clock works on it.
