05-09-2019 02:04
05-09-2019 02:04
I have a pair on Planetronic wireless earphone and these unfortunately wont pair with my Versa, so I've now purchased a pair of Huawei Freebuds and these will not pair with my Versa either. I've read all the chats on here and I've tried everything but nothing seems to be working.
Can anyone help me and does anyone know if Fitbit is sorting this problem out because I think its quite pathetic that they cant get this right. They need to release new firmware that allows all earphones to connect to them ASAP.
Thanks,
Sean.
05-11-2019
06:50
07:56
05-11-2019
06:50
07:56
Hello @SeanGildenhuys thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. Would it be possible for you to let us know the exact troubleshooting steps you've tried so far? This will be very helpful for us to check this further and determine what we should do next.
Thanks for your patience and understanding, we'll be waiting to hear from you.
Best Answer06-23-2019 09:43
06-23-2019 09:43
I too have the same problem.. My fitbit ionic will not recognize my huawei freebuds
Best Answer11-18-2019 02:08
11-18-2019 02:08
I'm also facing the same issue the versa finds the hwawei freebuds when searching but just doesn't pair up successfully. Keeps on with the status pairing freebuds lite for almost forever.
Best Answer12-29-2019 11:37
12-29-2019 11:37
Does anyone have any suggestions? or is this a firmware issue?
