08-28-2019
18:02
10:40
GraceGFitbit
08-28-2019
18:02
10:40
GraceGFitbit
My Fitbit Versa was able to download and update the firmware however now even though it says that it is downloaded, it is stuck on the Fitbit logo and won't go past this. It won't respond to anything that I am doing. Any ideas? I have factory reset and also restarted without success.
08-29-2019 01:56
08-29-2019 01:56
Hi @Tinasdsu I have flagged a moderator to come and help you
Helen | Western Australia
08-29-2019 10:50
08-29-2019 10:50
Thanks for participating in the Fitbit Forums @Tinasdsu. Let me give you a warm Welcome to our Community. Thank you for pointing this out @NellyG.
I would like to thank you for all your efforts looking for a solution. Lets check the following:
With those requirements in order, please delete your Versa from your Fitbit account and try to set it up as a new device again. You can also try the update steps or setup logging in to your Fitbit account on a different compatible device.
Give it a try and keep me posted in case you still need help.
Best Answer08-29-2019 10:57
08-29-2019 10:57
