03-06-2022 07:06
03-06-2022 07:06
My Versa keeps losing connection with my I phone 13 ever since Verizon went to 5 G and it doesn’t track my sleep either. Any help?
thanks
Chuck
Best Answer03-06-2022 07:19
03-06-2022 07:19
@Toledochuck1 Welcome to the Fitbit community.
First, this is the Fitbit Sense section. So a moderator will probably move this to the Versa section.
Secondly, maybe state if you have a Versa 1 or 2 so it can be moved to the right one.
As for your connection issue, is everything updated? Your Versa, the Fitbit app, and your iPhone? How are you aware of the disconnect, is it from the phone icon with diagonal line showing on your Versa? And is this happening with your iPhone close while on you or when far away?
One basic troubleshooting fix for connection/syncing issues is to delete your Versa and then add it again. You won't lose any data and the only thing that resets is the weather app to Celsius if you usually use Fahrenheit.
Best Answer03-06-2022 10:43
03-06-2022 10:43
Hi @Toledochuck1, I have moved your post to Versa board (you do not say which Versa you have) I'm confident a community member with Versa experience will be happy to assist you.
Cheers
Gr4ndp4 | UK
Best Answer03-06-2022 11:32
03-06-2022 11:32
Best Answer03-06-2022 12:06
03-06-2022 12:06
@Toledochuck1 I'll now move your post to the Versa 2 board.
Cheers
Gr4ndp4 | UK
