06-22-2020 04:41
06-22-2020 04:41
Hi Guys,
I've had my fitbit since December had no issues. Today I went for a walk and during the walk i noticed the fitbit restarted itself a couple of times (maybe 3/4 times actually in a 90 minute period)
After googling decided to do a factory reset, now when i try to set it up as a "new" device. After fitbit searches for the device it says "found it" then stays on "connecting to device"
Have tried turning bluetooth on/off, uninstalling and reinstall fitbit on the iphone etc. Cant resolve it.
Any help massively appreciated.
Thanks!
06-22-2020 04:51
06-22-2020 04:51
As often the way after about 30 minutes fiddling about couldnt resolve it.
Then 2 minutes after posting here I manage to fix it.
Problem was solved by downloading the fitbit app on my Laptop instead of using iphone, I then connected to the fitbit via my computer setup the device there. Then when I reloaded Fitbit on the iPhone it worked as though wasnt any problems prior.
Hopefully the factory reset has resolved the original problem i was having of the fitbit restarting itself during a workout.
06-22-2020 09:44
06-22-2020 09:44
Now it wont connect to either computer or Iphone, tried restart on both computer/iphone and obviously the fitbit.
So inconsistent, really disappointing.
