07-29-2020 05:08
07-29-2020 05:08
My verse is on dim. When I swipe left and go to settings the brightness tab is greyed out and will not allow me to change the setting. All other sections are bright and work.
07-29-2020 07:22
07-29-2020 07:22
Maybe you are in 'Sleep Mode'.
| Sleep Mode
| When you turn on the sleep mode setting:
To schedule sleep mode to automatically turn on during certain hours, open the Settings app
and tap Sleep Mode > Schedule. Sleep Mode automatically turns off at the time you schedule, even if you manually turned it on. You can't turn on do not disturb and sleep mode at the same time. |
07-29-2020 07:56
07-29-2020 07:56
Best Answer08-28-2020 17:45
08-28-2020 17:45
I have the same issue. Have reset, and shut down, everything but factory reset. Still can’t change brightness. 08-28-2020
Best Answer09-01-2020 19:38
09-01-2020 19:38
I had this issue appear suddenly. Long story short: "Sleep Mode" had turned "on". Turned "Sleep Mode" to "off". Now "Brightness" option is available and adjustable.
