06-25-2018 10:21
06-25-2018 10:21
Is there a setting where my Versa can vibrate on the hour instead of 10 minutes before?
06-25-2018 14:21
06-25-2018 14:21
@Tori-Ann The vibration 10 minutes before the hour is to remind you to get your 250 steps in that hour. You could probably set alarms to go off on the hour in the Alarm app. Not sure how many are supported. And I know that more alarms and more vibrating will reduce your battery life.
