Vibration not working for text/call notifications
ANSWERED
My versa isn't vibrating or telling me when i get a call or text.  When i pull down they are there but i want the notification.
390 REPLIES 390
Thank you. Issue solved
I tried everything in this thread and this is what fixed it for me. “Hold back button and swipe left. Notifications was turned off.”
Thanks.
This totally helped! I didn’t even think of that! I bump to that screen on accident all the time!
Thank you for this response!!  That was my problem too.  I guess I had pushed the left button and turned off my notifications.
thank you Smiley Happy
Hi has any discovered just recently vibration not working again.  Is this a universal problem.  We have three Fitbit wearing people in our house and all are not receiving vibrations on their watches .
Mine was doing the same thing but my notifications on my fitbit was turned off. Hold down on the left button and make sure your notifications are set to On.
Sent from my iPhone
Worked for me too! Thank you  Darbry
Yes always check that and was turned on.
Thank you!!!
This fixed the issue... I guess I somehow accidently did this in my sleep or something.
I was having the same problem. Try this..
1. turn off notifications by clicking  left button for 2 seconds.
2. Sync your watch
3. Press and hold the left and bottom button until you see the fitbit logo on the screen. This should take less than 10 seconds.
4. After restarting, sync the watch again, and turn on notifications.
5. Test your notifications and see if they go thru.
Hope this helps!
Thanks for the help
Other notifications are coming through my Fitbit but text messages/ calls are not sending notifications.
This WORKED!! thank you so much!
I've tried all of these troubleshooting techniques too, but my fitbit keeps kicking itself off of my phone's bluetooth. However, even when I go into notifications and do the "test call", while it IS connected to bluetooth, it still doesn't send me the test call.
Thank you!
Try this:
1. Hold the right left button down to turn OFF notifications.
2. Sync your phone via the Fitbit app
3. Press and hold the the left and bottom right button until the Fitbit logo appears on your watch
4. Sync the watch again via Fitbit app
5. Hold right button to turn on notifications
6. Test your texts/calls
G’luck
Sent from my iPhone
I have the Versa lite, so I don't have the buttons on the right, but thank you anyways for trying to help!
Thank You. It's always the simplest solutions that I like the best! This was my issue.
So glad I did not do a full factory reset before figuring out how to turn the notifications back on.
This answer should be at the top of the thread.
Thanks hahaha!
