04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
06-24-2019 17:37
06-24-2019 17:37
worked great and also applied the same to my husband's Blaze (just different buttons) and it works now also! Thanks JazAmazin!
06-25-2019 12:38
06-25-2019 12:38
Thanks after resetting everything and it not working holding the left button in I turned it in and it all works again phew
07-01-2019 12:25
07-01-2019 12:25
Hold left button down and see if option to turn on notifications is there.
07-01-2019 12:26
07-01-2019 12:26
07-01-2019 22:31
07-01-2019 22:31
I’m not seeing any answers that actually help so I’ll lay out what worked for me. I did all of the resetting and nothing fixed it until I found a dumb hidden setting!
Even if you have vibration on and notifications on from the Fitbit app itself, THERE IS A HIDDEN SETTING ON THE VERSA DEVICE - hold down the left button until a quick menu pops up and make sure notifications are ON here. Solved it all for me.
Hope this helps!
07-08-2019 18:24
07-08-2019 18:24
I must have done this by accident! I checked and this was my issue. Recommend people check this first before all the repairing & resetting.
Best Answer07-09-2019 09:25
07-09-2019 09:25
Thanks for this - I have tried everything to get the vibration on my versa working again - your solution worked.
07-09-2019 10:17
07-09-2019 10:17
That’s great! Really happy it worked for you. I know how frustrating it is when your watch isn’t functioning properly. 👍🏽💪🏽😉
Best Answer07-09-2019 20:07
07-09-2019 20:07
I’ve tried this and a simple restart and all the suggestions above. Still no vibrations for anything. Is this a device or software fault? There isn’t much point in an alarm or a stopwatch if it doesn’t vibrate 😬. Any new ideas?
Best Answer07-16-2019 08:57
07-16-2019 08:57
I've been experiencing the same issue where my missed calls and all texts are on the Versa but it wasn't vibrating when they came in. To elaborate on your post, I held down the left button and discovered notifications were turned off. Very simple fix. Thank you!
Best Answer07-16-2019 18:33
07-16-2019 18:33
Vibration works for alarm and timer but still not working for calls, texts, etc.
Best Answer07-17-2019 07:37
07-17-2019 07:37
Hsdan,
Have you tried holding down the left button for a few seconds? It should display a screen that has notification on or off.
07-27-2019 19:42
07-27-2019 19:42
Thanks so much this totally fixed my problem. Didn’t even know and or think of this. Don’t know how it got turned off. Glad it’s working again.
07-28-2019 06:55
07-28-2019 06:55
Awesome!! 👏 😎 really happy to help.
08-11-2019 12:34
08-11-2019 12:34
Thank you so much! I tried the other solutions in this thread and none worked. I followed your steps and I am finally getting my notifications again! Yea! Thanks so much!
08-11-2019 14:19
08-11-2019 14:19
Really happy it helped. Happy stepping, friend! 💪🏽
Best Answer08-12-2019 08:30
08-12-2019 08:30
I had this problem. The online chat agent showed me that if you hold down the back button only, two options come up: Awake and Notification. Check that the Notification in that screen is on.
08-13-2019 11:05
08-13-2019 11:05
I had the same problem but I found the cause for mine! If you hold down the left side button it bring’s up a new screen with screen awake and notifications. All you need to do is tap notifications on 👍🏼
Best Answer08-18-2019 19:27
08-18-2019 19:27
Thanks! Got mine working again. Didn’t know where this feature was. Accidentally turned notifications off while changing my band. U rock!
Best Answer08-22-2019 02:52
08-22-2019 02:52
Excellent solution thanks! My daughter had the same issue and I couldn't work out why the notifications weren't showing. It was exactly what you suggested. The notifications on the Versa itself were switched to off.
