Vibration not working for text/call notifications
ANSWERED
My versa isn't vibrating or telling me when i get a call or text.  When i pull down they are there but i want the notification.
390 REPLIES 390
Thanks for that Tristian- it helped me.!
Yes!!! That fixed it for me!
It works for me now. Thank you
Jbolling- worked for me! Thank you!
let everyone know when u have the answer.  Seems like this is a common problem.
I restarted my fitbit in two different ways, my fitbit does vibrate for other things just not iphone calls and msgs.  This started with the IOS 13 update. .I'm growing very frustrated. .I'm missing calls and msg at work as I can't have the volume up
If you go into the iPhone
Settings
Notifications
Make sure that messages are on show previews when unlocked
Sent from my iPhone
Hi Jeff, I did go into settings and for my entire phone, notifications were "always" on.  Then I went to Notifications for Fitbit and it was off, like you thought I switched it on and it is still not working.  I will reset the fitbit again with these new settings and crossing my fingers that it works.  Thanks a bunch for your suggestions.  Most appreciated. . .JoJo
Updated to the new Firmware and now I’m not getting notified of new notifications. DND and sleep mode are both off. I can see my notifications when I swipe down. It’s just not vibrating. Support hasn’t been helpful. So frustrated that I updated.
Same boat here. So frustrating!
@Kings2020
Same.
This happened to me after installing the Fitbit firmware last night. (It is not an iOS 13 issue as they keep sending me to that thread for instructions on how to fix it)
I’ve chatted with support, emailed, sent a message through messenger and no one knows how to fix the issue. Simply frustrating.
Sent from Yahoo Mail for iPhone
make sure dnd isn’t off on your phone
Sent from my iPhone
I “forgot the device” , then reconnected it and IT WORKED!!! I am so happy to have my Versa vibrate to a text message again. Hopefully this helps anyone else.
Tried it again today and doesn’t work for me. Still no vibration for notifications. Happy it worked for you though 👍😊
Happy it worked for you but it didn’t work for me though. I tried this twice yesterday as well. But glad your Versa is back up and running
If you press and hold the home button a screen will show screen wake and notifications. Tap on notifications for yes, I hope this does it for you. This is what I did and it works for me now.
The screen is no longer there when you update to the new Firmware.
Have you tried holding the button on you watch down for a few seconds it will display the notification selection and that should be turned on
Have you checked the settings on your watch to make sure the vibration is set to STRONG then hold down the button on your watch for a few seconds, the notification settings should appear make sure that is turned on as well.
