04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
02-03-2020 08:26
02-03-2020 08:26
02-06-2020 10:37
02-06-2020 10:37
I wasn't getting notifications at all but I unpaired my device, reset my phone and then paired again. Now I can see the notifications but I don't get a vibration. It did vibrate for notifications when plugged into my charger this morning but it's not on my wrist. Can anyone help me with this?
02-06-2020 12:32
02-06-2020 12:32
02-16-2020 14:47
02-16-2020 14:47
Mine is also not vibrating when I get a call or text after my last update. I have checked to make sure everything is turned on. I have done the alarm test and sure enough it vibrates. But it does not for calls or texts any more.
Oh and it also stopped alerting me when its 10 to the hour.
So both of those functions have stopped working with the last update.
At least the alarm still works but I would really like it to remind me to move every hour. And get my calls.
Thank you
02-16-2020 19:23
02-16-2020 19:23
02-24-2020 16:52
02-24-2020 16:52
I was having the same problem. If your sound is off on your phone it will stop texts from vibrating. Just turn ringer up. I hope this helps. It fixed mine.
03-07-2020 20:09
03-07-2020 20:09
I have Fitbit versa and iPhone XR. My text notifications do not vibrate and my weather app on my device does not pick up current location. I tried all I can and 4 different customer service people could not solve it either. All they said is waiting for next software update to come, to hopefully solve the problem. They do not know when the software update will happen either. This is unbelievably bad answer to the issues like these. I got this for 6 months and they cannot return either. Very unhappy about their technical solutions. Does anyone have the same issue?
03-07-2020 20:21
03-07-2020 20:21
I don’t know if any Fitbit development team is checking these comments. It is very frustrating that things like this does not work. Today the customer service person asked me to update my IOS and I did but still text does not vibrate. Somebody from the company technical team must work on providing a solution for this!!! My versa stopped working after last device software update! How come they did not give a full test of their products before they released it!!!
03-07-2020 20:25
03-07-2020 20:25
I called more than 4 times, still not working. Totally a waste!
03-08-2020 19:04
03-08-2020 19:04
03-08-2020 23:47
03-08-2020 23:47
03-09-2020 04:51
03-09-2020 04:51
05-12-2020 21:15
05-12-2020 21:15
Good luck with that for us. I got my Versa 2 Friday, May 8. By Sunday, the 10th, suddenly no more vibrations for notifications. If I pull the screen down they're there, but no vibration. I can only guess when they'll do a firmware fix and I certainly won't hold my breath. So far it's been a very expensive waste.
05-13-2020 06:06
05-13-2020 06:06
05-13-2020 09:52
05-13-2020 09:52
06-04-2020 18:12
06-04-2020 18:12
Hi moderator! My fitbit is doing the same thing! If the support team can find anything to suggest to @nimR@d, please send me the help too. I have tried everything & I seriously rely on the notification!! That is what drew me to fitbit in the first place!!
06-18-2020 13:46
06-18-2020 13:46
Doing a factory reset of my fitbit was the only thing that fixed this issue! But I am getting my notifications again.
06-18-2020 14:24
06-18-2020 14:24
Thanks. I have tried that several times now! It worked once for about a second or two! The crazy thing is, now the calls are coming through on vibration, but still nothing else is. Not doing good or happy with it!
06-23-2020 05:59
06-23-2020 05:59
I am having the exact same issue with my Versa Lite. I have unpaired it, reset all settings, removed app and reinstalled, etc. I receive text notifications and vibrations for other things fine, but receive no call notifications.
07-05-2020 15:49
07-05-2020 15:49
Tried but did not work for me...desperate missing this!
