04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
07-13-2020 23:01
07-13-2020 23:01
Brilliant! I feel like a doofus 🤦:female_sign:
07-14-2020 13:04
07-14-2020 13:04
my Versa is also not vibrating for texts or phone, but is vibrating for alarms. There was a suggestion about disabling device lock. I do not see that anywhere. How do I find it?
07-14-2020 14:45
07-14-2020 14:45
ur welcome 🙂
07-14-2020 14:48
07-14-2020 14:48
Go on the Fitbit App, Than go on your account, Next click on your Versa 2 and scroll all the way down and it will be the second last option.
Hope this helped:)
07-14-2020 14:50
07-14-2020 14:50
Lmao, Apple watches are good too but I'm broke lol
07-14-2020 18:54 - last edited on 07-29-2020 20:27 by LiliyaFitbit
Believe me you're not alone. Glad you got it working.
07-15-2020 05:33
07-15-2020 05:33
I have a Versa, not Versa 2. If I follow your instructions, my last 2 options are
All Day Sync, then Sync Now, and lastly, remove this Versa
07-15-2020 05:52 - last edited on 07-29-2020 20:28 by LiliyaFitbit
I have Versa. I sync all day because I have notifications to move on. I
recommend "all day". Make sure in the actual Versa settings, you have
Vibrations on.
Good Luck.
07-15-2020 10:06
07-15-2020 10:06
07-18-2020 07:46
07-18-2020 07:46
I did the same steps. Any YouTube videos that you found? If they work please keep me updated!
07-29-2020 09:03
07-29-2020 09:03
I wasn't working for me also but then I went settings on my watch and apparently my do not disturb was on so I turned it off and it worked
07-29-2020 13:44
07-29-2020 13:44
09-12-2020 16:42
09-12-2020 16:42
I did all that. The vibrate works fine. I have unpaired, uninstalled, restated everything multiple times to on avail. Please I am on crutches and can't always get to my phone. I need this to work again
09-15-2020 03:42
09-15-2020 03:42
I had the same issue, and it was just that Settings for Do Not Disturb was activated. Alarms would work as normal, but calls and messages wouldn't vibrate, just appear on the fitbit. Press and hold the side button and deactivate "DND" at the top of the menu that comes up.
09-27-2020 15:08
09-27-2020 15:08
Mine is doing the same thing. I gave tried everything! Nothing helps. Been doing it since last update!
09-27-2020 17:02
09-27-2020 17:02
09-27-2020 20:43
09-27-2020 20:43
09-27-2020 21:54
09-27-2020 21:54
My vibration is working with timer, exercise etc but I’m not getting calls or texts. I feel like I’ve tried everything?? Help...
09-28-2020 04:39
09-28-2020 04:39
09-28-2020 04:42
09-28-2020 04:42
