04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
06-07-2018 04:57
06-07-2018 04:57
I found the fix on a different discussion board this morning. Hold the left button down until the notification setting pops up and make sure it is on. Mine had turned off.
06-07-2018 06:33
06-07-2018 06:33
Happened to me also... I fixed it by removing Versa from the app on my phone and resetting it up and skipping wifi setup. Works now but not real consistent but then it was like that before when it used to work. YMMV.
06-07-2018 14:00
06-07-2018 14:00
I was having same trouble - Versa not vibrating when receiving notifications.
I did as suggested by MEBates and my Notifications was "off". I turned it "ON" and am now receiving vibration when receiving a notification!
Thanks for the info on the fix!
06-07-2018
20:13
07:28
AlejandraFitbit
06-07-2018
20:13
07:28
AlejandraFitbit
Come on Fitbit, what are you going to do about just getting missed calls on the Versa & not even vibrating to let us know a call is coming in? Talked to customer service about it 2 weeks ago & they walked me through everything and still unsuccessful, that was one of the features that drew me to the Versa. I guess I should have just stuck with my Alta.
06-08-2018
04:19
10:03
06-08-2018
04:19
10:03
Hey everyone!
It's great to hear that for some of you this issue has been resolved and thanks for sharing the steps you did in order to fix this. For the ones that still having this problem, I would like to know if you have checked whether the device lock is enabled or disabled:
If it is enabled, do the following:
Let me know how it goes. ![]()
Best Answer06-08-2018 12:20
06-08-2018 12:20
Notifications stopped showing on watch face and notification vibrations stippled at the same time. All notifications from phone show in list but no vibration or drop down on watch face,
Best Answer06-08-2018 12:47
06-08-2018 12:47
Never mind I fixed it. Hold back button and swipe left. Notifications was turned off.
06-10-2018
07:49
10:02
06-10-2018
07:49
10:02
It's great to see you around @SunsetRunner.
I am sorry to hear about the notifications issues you are experiencing and thanks for troubleshoot this by yourself. If you haven't checked the help article My Fitbit device isn't receiving notifications from my phone, I recommend doing it and follow the instructions provided there.
Let me know the outcome. ![]()
06-10-2018 18:47
06-10-2018 18:47
don't know how... but it worked... thx
Best Answer06-13-2018 13:11
06-13-2018 13:11
Just bought the versa as early as yesterday 6/12/18. Upon setting it up everything functions as it should but the vibrations do not come through for texts all the time. Calls yes, timer yes, alarms yes. I’ve restarted, reset, unpaired, repaired, uninstalled.. literally everything I’ve found on here. To no avail has it worked. This seems to be junk currently. When i get it to work it stops hours later. I have sync on all day and my phone is never more than 10 feet away from me, just not always accessible hence why this is a problem.
Best Answer06-13-2018 16:52
06-13-2018 16:52
Time to contact Customer Support.
Best Answer06-18-2018 20:14
06-18-2018 20:14
Thanks for sharing that feature! I think that’s what the issue was with mine and I hadn’t even realized I’d turned them off! Fingers crossed that it was the issue, I don’t want to deal with the hassle of doing the hard reset
Best Answer06-21-2018 10:37
06-21-2018 10:37
Did you ever get a resolution? Mine is doing the same thing. I only get notifications when it's time to get more steps in to meet my daily goal.
Best Answer06-21-2018 10:40
06-21-2018 10:40
My vibration feature is turned on and still doesn't work. Turned it on and off with the left button you mention and still not vibration other than reminding me to take my steps.
Best Answer06-21-2018 11:06
06-21-2018 11:06
Best Answer06-21-2018 11:28 - last edited on 10-06-2019 14:00 by LiliyaFitbit
I have done all of those things already. Worked for a day and then stopped again.
Sent from my iPhone
Best Answer06-21-2018 12:37
06-21-2018 12:37
Best Answer06-21-2018 17:31
06-21-2018 17:31
Wow....the moderator couldn't suggest this? Great tip and fixed my problem! Thanks!
Best Answer06-22-2018 18:40
06-22-2018 18:40
I am having the same issue. I have been in contact with fitbit for 2 days and we just keep troubleshooting the same way....over and over again.
The link isnt helpful, I am receiving notifications, my Versa just wont vibrate.
06-23-2018 17:02
06-23-2018 17:02
I am having the same issue. I just recieved my watch yesterday and it was vibrating yesterday, but today it is no longer vibrating and I have not changed anything.
