04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
08-21-2018 10:16
08-21-2018 10:16
This fixed my issue. Thanks! I didn't even know this was a feature!
Best Answer08-23-2018 10:59
08-23-2018 10:59
I was having the same issue, and as I was messing with my versa trying to fix it, I held down the lock screen button for a moment and the options of "screenwake" and "notifications on/off" popped up and I realized that I must have accidentally turned my notification setting off at some point.
So maybe check that
08-29-2018 02:02
08-29-2018 02:02
I’ve recently been having issues with mine. Unfortunately I don’t have time to read all the pages and pages of this. But I was wondering if it’s an Apple thing. Apple already wouldn’t let us reply to texts from versa. I got mine end of may for my birthday. It’s perfect. But within the last couple weeks, it’s stopped vibrating for texts and calls. They’re still there when I swipe down. But no alert. I did as you said about the “device lock” however, I can’t find ANYTHING on my app with that’s option..
Best Answer09-02-2018 08:09
09-02-2018 08:09
Thank you!! My daughter and I have tried everything we could find and searched everywhere with no resolution. This finally fixed it. Thanks for sharing!!
Best Answer09-03-2018 21:02
09-03-2018 21:02
Best Answer09-06-2018 03:23
09-12-2018 16:58
09-12-2018 16:58
I just received my versa yesterday. I do not get the vibrations for any texts, emails, phone calls, or my alarm. I have uninstalled and reinstalled Fitbit app. I have changed the vibration from normal to strong. I had an Alta and it died on me, wouldn't stay on once taken off the charger and no answers on how to fix it. So I thought I would buy a versa instead. Didn't really want to spend this much but thought I would give it a try. I would really like it fixed to work properly for the money I spent. I have been a Fitbit wearer for over 5 years. Do I need to return the versa and go to a different brand?
Best Answer09-12-2018 17:00
09-12-2018 17:00
Best Answer09-12-2018 17:03
09-12-2018 17:03
Best Answer09-12-2018 17:37
09-12-2018 17:37
Best Answer09-13-2018 00:26
09-13-2018 00:26
This! Was just about to smash my Versa to bits and found this response - I think while changing the strap I had somehow turned this feature off and now the vibrate is back when a text/call comes through. Thanks
Best Answer09-13-2018 03:26
09-13-2018 03:26
Best Answer09-13-2018 10:21
09-13-2018 10:21
Best Answer09-13-2018 11:44
09-13-2018 11:44
Changing my strap was quite fiddly so I kept pressing all the buttons and touching the screen etc. while doing it. When when I checked after reading this post, by pressing and holding the left button, and seeing that the notifications were off, I turned them back on and it now works. I didn’t turn them off it myself so can only assume that I somehow did it with all the fiddling about.
Best Answer09-18-2018 12:48
09-18-2018 12:48
My versa is having the same problem. I am getting the notifications on my Fitbit but it is not vibrating. I reset it then nothing. I uninstalled and reinstalled it. It is still not vibrating. What should I do now?
Best Answer09-18-2018 13:08
09-18-2018 13:08
Best Answer09-19-2018 08:04
09-19-2018 08:04
i have been having this problem for months. i have tried all of the troubleshooting. sometimes it will work for a few hours and then stops working again. i am missing a lot of texts and phone calls because of this. i have contacted fitbit support several times, have been assigned a case number but they just keep saying they hope it will be fixed with the next update. i am thinking of returning my versa and going to the apple watch! i didn't have any of these problems with my alta. i have been a fitbit user since the fitbit one!
Best Answer09-21-2018 14:21
09-21-2018 14:21
@MEBates THANK YOU!!! Your post helped me fix my issue!!!
09-25-2018 09:19
09-25-2018 09:19
I had been frustrated by this issue for weeks, till I read your post, many thanks
Best Answer09-27-2018 16:52
09-27-2018 16:52
I was having this issue as well and tried all the steps except for removing my Versa from the Fitbit app and reinstalling. It still didn't work so I decided to remove my Versa from the app and then reinstall it again. Now it works perfectly. Thanks for all the suggestions!
