Vibration not working for text/call notifications
ANSWERED
My versa isn't vibrating or telling me when i get a call or text.  When i pull down they are there but i want the notification.
390 REPLIES 390
Yes! Mine all said the notifications were on too. What a weird option to
not be synced the same. Glad it helped!
This is too funny. My name is Ashley Nicole too! Lol
I appreciate all of the suggestions but not one of them works.  My notifications are on - on both my Veras as well as in the Fitbit App, and on my IPhone. I have restarted it twice.  I will have no choice but to call Fitbit when I have some time to do so.  I note that the vibration works when I hit my desired steps per hour but not for calls, texts or appointments. This is very frustrating because they once worked and now they don’t.
Omg!! Thank you so much!!
Yep. That fixed mine.
Tristian,
Your  answer saved my day.
Seems this should be part of the default troubleshooting..
thanks !!
I just checked and this was my problem!! Thanks!!!
I said That same thing! You are welcome!
I do not seem to have  the Device Lock option. I have reset my Versa, restarted it, and tried numerous things but it still is not vibrating to notify of phone calls or text messages.
IJohnson, press and hold the left button, then swipe to find the notifications/music menu. Press notifications ON/OFF
The notifications are on but it still isn't working.
I would Call Fitbit customer service then. Maybe something is wrong
internally. If the settings in the bit and the app is on?! They may have a
reset. Have you shut it down?
Ashnicole
I have. I've restarted it, shut it down, and tried to do a factory reset.
I did that and it compromised my battery life. I have little time to sit on the phone with Fitbit to fix this problem. Saving for an Apple Watch.
Sent from my iPhone
Check to see if your multiple Fitbits are showing as connected to your
phone. Somehow mine was connected multiple times so nothing was working
properly.
This is exactly what my problem was! Thank you so much! I did all the other recommended things and it didn't help.
You are so welcome! Nothing like helping each other out!
You have just saved my life lol
Hahaha I felt The same way
This fixed mine! I must have accidentally turned it off when I was scrolling through settings or something. Thank you so much!
