04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
09-28-2018 06:18
09-28-2018 06:18
Best Answer10-01-2018 19:12
10-01-2018 19:12
THANK YOU for sharing!!!! I had no idea this was done on my watch (I think kids touching it) and I couldn't figure it out for the life of me!!!!!
After a week of trying, I found your post and TA-DA! SMH!
TYTYTY
Best Answer10-02-2018 09:44
10-02-2018 09:44
Thank you, you are a genius! I went through everything including downloading the latest IOS update and just saw your message. Mine was off too, had no idea that button did anything except display the clock face. Thank you, thank you!
Best Answer10-03-2018 08:35
10-03-2018 08:35
I tried everything and just realized I'd somehow done the same thing with the left button. Thank you!!
Best Answer10-05-2018 04:07 - edited 10-05-2018 04:33
@Tristian101 Thank you! I spent 2 days trying to figure it out. THIS WORKED!
Best Answer10-05-2018 18:59
10-05-2018 18:59
I am having the same problem. Text/call notifications have no vibrate but show up on the screen if I go on and pull down from the top. I tested the alarm and it vibrated. I have restarted my versa, restarted my phone, connected and disconnected Bluetooth, my app is updated. Not sure what to do next. I know it has worked because it did when I first got it a couple months ago but shut the vibrations for notifications off at the time. Now I try to turn them back on and nothing is happening. Very frustrated!
Best Answer10-05-2018 20:17
10-05-2018 20:17
Have you tried holding the left side button in for a few seconds and see if notifications has been turned off? If so, just turn it back on...
Best Answer10-06-2018 00:00
10-06-2018 00:00
Best Answer10-06-2018 12:08
10-06-2018 12:08
Best Answer10-06-2018 13:28
10-06-2018 13:28
I am having the same problem. Vibrates for Alarm and during exercise but not for any text or call notifications. I do not see a device lock anywhere on the account?
Best Answer10-10-2018 01:48
10-10-2018 01:48
Hi my fitbit versa after charging completely today has stopped vibrating on notifications and calls , i tried all steps of re installing and restarting my fitbit, but still no luck.
Please help me on the same.
Best Answer10-14-2018 07:31
10-14-2018 07:31
The account page on my fitbit app (on iphone) doesn't have anything related to Device Lock. Is this a new feature? If so, do I need to reinstall the app?
Best Answer10-27-2018 12:13
10-27-2018 12:13
Thank you so much for this, mine stopped working a few days ago and ive just spent over an hour trying to fix it restarting my fitbit, deleting the app, restarting my phone everything! turns out i had sone the same as you some how 🙈
Best Answer11-06-2018 05:31
11-06-2018 05:31
I was going crazy trying to figure out the solution to this problem - UNTIL I scrolled down and saw your response. Thank you so much for this post - it fixed the issue and prevented me form throwing the watch in the garbage.......thanks again!!!!
Best Answer11-06-2018 06:25
11-06-2018 06:25
Could somebody please tell us exactly *what* solved their problem? One of the suggestions is to turn screen lock back on If that was what solved several people's problem, how does one turn it on? I can find nothing on the fitbit app that deals with screen lock. Thnaks!
Best Answer11-06-2018 06:48
11-06-2018 06:48
Best Answer11-06-2018 06:56
11-06-2018 06:56
Ah, so simple when you know how, thanks very much.
Best Answer11-06-2018 07:03 - last edited on 10-06-2019 14:03 by LiliyaFitbit
I agree - I was going crazy trying to find the solution!!
Sent from my iPhone
11-10-2018 14:47
11-10-2018 14:47
Thank you, this worked for me too. It's crazy how in the morning it vibrates & by nightfall it no longer does. AGH!!!!
Best Answer11-28-2018 10:30
11-28-2018 10:30
You are a genius!!! I was on the phone with fitbit customer service and did everything under the sun and nothing was working. I read your post and sure enough...notifications were off. Thank you thank you thank you!
