04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
11-28-2018 10:56 - last edited on 10-06-2019 14:03 by LiliyaFitbit
Glad it helped!!
Sent from my iPhone
11-28-2018 18:05
11-28-2018 18:05
Thank you!!! I tried all of those other crazy resets, but this was the one I needed. Yippee!!
Best Answer11-30-2018 12:22
11-30-2018 12:22
I just spent and hour with customer service - They think its an actual problem with the versa and the software. This just worked and you are a PURE GENIUS!!! THANK YOU
Best Answer12-03-2018 10:02
12-03-2018 10:02
Genius!!! Mine works again! Thanks!
Best Answer12-04-2018 13:36
12-04-2018 13:36
Had this problem and now sorted the support centre helped. Press back button and swipe left on screen and then turn on notifications.
Best Answer12-05-2018 05:19
12-05-2018 05:19
Best Answer12-07-2018 05:27
12-07-2018 05:27
Hahahahah!!!! So simply! Thank you! That was my problem. Good to have smart people around! 🙂
Best Answer12-10-2018 21:14
12-10-2018 21:14
Yes tried that was enabled and also used side button to check notifications on. Verse vibrating for everything except texts or
phone calls. Seems to be a wide spread fault !!!
Best Answer12-10-2018 21:48
12-10-2018 21:48
Where did you find quick setting? Thanks.
my notification is on but still Not vibrating for texts
Best Answer12-10-2018 21:51
12-10-2018 21:51
Ditto - same problem.
Best Answer12-11-2018 10:01
12-11-2018 10:01
Can you please escalate mine to the support center as well? My vibrating works when my watch lets me know that I need x amount of steps left this hour, but otherwise the vibration does not work.
Best Answer12-14-2018 07:54
12-14-2018 07:54
I had the same issue a few months ago. I had online help/chat walk me through a bunch of steps and got it working again.
I noticed today that it's not vibrating again. Before getting on with chat, I decided to give the back of the Versa a wipe down with a Clorox wipe. I put the Versa back on and the very next text message I got the Versa vibrated.
I noticed people with tattoos on their wrist are having problems too, so it seems to be a problem with the HR sensor.
I never take mine off except to shower and to charge it, so it gets pretty grimy on the back (I know - YUCK). So going to try to be better about keeping it clean.
Hope this easy fix works for some of you!
12-18-2018 19:44
12-18-2018 19:44
Tried doing all steps mentioned and vibrating isn’t working for texts. Help!
Best Answer12-18-2018 21:08
12-18-2018 21:08
Best Answer12-19-2018 17:49
12-19-2018 17:49
Best Answer12-20-2018 19:27
12-20-2018 19:27
Thankyou so much
Best Answer12-23-2018 00:49
12-23-2018 00:49
Vibration for texting has stopped working again - tried updating iPhone again but vibrating did not work
this time. Pretty disappointed!!
Best Answer12-23-2018 04:25 - last edited on 10-06-2019 14:04 by LiliyaFitbit
Try factory reset. If that doesn't work, call FITBIT. Tell them all you
did, they will have you repeat them if you don't.
Best Answer12-23-2018 12:27
12-23-2018 12:27
Best Answer12-31-2018 17:23
12-31-2018 17:23
Genius! We were changing my band and suddenly stopped vibrating for text. Didnt know this about this button! I'm back to getting notifications! THANKS!
