04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
01-01-2019 07:36
01-01-2019 07:36
Mine was doing the same thing.. I just hold the left button in till the notifications icon came up and I turned it off and open twice and now it’s working. Don’t know if that will help u.. but worth a try..
01-01-2019 17:38
01-01-2019 17:38
Its been driving me crazy that my vibration wasnt working when a text or call came through! I came across your post and it worked!! I was getting so frustrated. Thankyou!!😁
01-04-2019 11:42
01-04-2019 11:42
I had this issue and then realised if I turn vibrate off my phone it also turns the vibrate off the fitbit. I turned my vibrate back on on my phone and the vibrate on the fitbit started again
01-04-2019 18:14
01-04-2019 18:14
This was exactly the solution; thank you so much!!!!!!!!
01-05-2019 03:07
01-05-2019 03:07
01-06-2019 13:59
01-06-2019 13:59
This was it!!! Thanks for sharing!!
01-09-2019 07:21
01-09-2019 07:21
I have tried all of the above things to get my versa to vibrate for calls and text messages, with no luck..
What can I do to correct this?
01-09-2019 12:35
01-09-2019 12:35
Hold the button on the left, then tap notifications.
01-10-2019 00:08
01-10-2019 00:08
01-13-2019 08:50
01-13-2019 08:50
I had the problem that I would recieve notifications on my versa but it wouldn’t vibrate. I found my issue was that I had my phone on do not disturb, so if you have that on then that might be why. 😂
01-14-2019 15:21
01-14-2019 15:21
Thank you!!! Been wondering and trying to trouble shoot this problem for at least a week now, tried this and it started working again. Must have pressed it when I changed my strap 😐
01-15-2019 03:04
01-15-2019 03:04
I was having the same problem when I was receiving my notifications. It would not vibrate but if I scrolled down it was there.
I came by the solution by accident. If you keep your finger on the single button on the left side of the watch a menu comes up for SCREEN WAKE and NOTIFICATIONS with on/off options. Turn it on and fingers crossed it should fix the problem. It worked for me
01-17-2019 17:03
01-17-2019 17:03
Thank you Tristian101!! Mine was turned off -- I guess it got turned off by accident. Working again now!!
01-22-2019 20:54
01-22-2019 20:54
Having this same issue, call Fitbit last week to try to get a solution and I was told it was a glitch they had been receiving complaints about but haven’t heard anything since!
01-23-2019 10:43
01-23-2019 10:43
01-24-2019 08:01
01-24-2019 08:01
Thank you. I forgot I had turned my notifications off.
01-24-2019 19:45
01-24-2019 19:45
Thanks!!! That worked
@Tristian101 wrote:Hi,
Had this problem, my fitbit versa suddenly stopped vibrating on notification, tried all of the tips here.
Then I realised.
If you hold the left button you can turn off notifications from your wrist, and then other night I had done just this from the cinema!
Useful feature, when you remember to turn it back on again!
01-26-2019 07:47
01-26-2019 07:47
I was having the same problem and none of the suggestions helped. I found that my phone was connected twice and a third that I didn’t recognize was also connected. When I disconnected all but one connection for my phone, the vibration and notifications started working as they should.
01-28-2019 04:08
01-28-2019 04:08
YES!!! That was TOTALLY what was wrong with mine! I did the same thing you did and tried sending myself notifications in the app, resetting bluetooth, AH! Thank you for posting this!!!
01-28-2019 18:21
01-28-2019 18:21
