02-23-2019 19:49
02-23-2019 19:49
When I receive a text on my versa, I can see it but only the first line of the message. It's like the versa has a character limit. Is there a way to view the whole message on the versa? And is there a way to compose a new text message on the versa?
Best Answer02-24-2019 00:42
02-24-2019 00:42
Hi @Mandolyn To view the whole message, tap it and it should display. You cant compose replies on the Versa, but if you are an Android user you can use one of a set of pre written quick replies. It comes with default message replies, but you can customise these in the app and then when a message comes in you select the quick reply most appropriate to answer the message. Thisnis not possible on iOS at this time.
Helen | Western Australia
