Voice cues during jog
ANSWERED
I wonder if the run app (under exercise) will ever offer voice/ auditory cues (e.g
 every completed mile and upon completion of set distance ,etc).  I am aware about visual cues but it is not the same (but are very welcomed)  Also, I attempted to use the Coach app but it is not what I need. Thanks
1 BEST ANSWER
Accepted Solutions
I think you can get that if you start run from phone app instead of from tracker, assuming you carry your phone on run.  From phone app, click exercise tile, then the stopwatch icon in upper right corner.
I haven't used this for a while so I forget the details.  I think it gives you a few options about when to get cues.
3 REPLIES 3
I am hoping that at some point they will add it to the Versa.  That I miss from the Nike App.  Thanks
It might be possible on the Versa, it would require connecting headphones to the Versa, existing feature, and the Versa would need to have some type of voice chip
