11-26-2020
12:13
12:54
11-26-2020
12:13
12:54
My voice replies no longer seem to be working. It just keeps showing me the spinning thing and says unable to send. And gives me an option. To retry or cancel. I just got my fitbit versa 2 5 days ago! My phone is a galaxy s10+.
11-26-2020 13:00
11-26-2020 13:00
Hi there @Chesney09, welcome to the Community Forums. Thanks for the details provided in your post and for letting me know the model of your phone linked to your Versa 2, I understand where your concern is coming from. I'll be glad to help you.
If you haven't done so yet, I'l recommend following these troubleshooting steps: What should I do if my voice assistant doesn't work on my Fitbit smartwatch?
Let me know how it goes.
Best Answer11-26-2020 13:00
11-26-2020 13:00
Best Answer11-26-2020 14:51
11-26-2020 14:51
I have a galaxy s10+. It worked perfectly fine up til today? I have tried restarting the Fitbit andt phone numerous times with no luck. This is really upsetting.
Best Answer11-28-2020 03:53 - edited 10-10-2023 05:14
Hey @Chesney09, I appreciate you had followed the tips and recommendations provided above.
Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
