07-12-2021
22:27
04:57
07-12-2021
22:27
04:57
my versa2 stopped text talk only after second day of using it. please can someone help.
07-13-2021 04:58 - edited 01-27-2024 13:23
Hi there, @ebversa2. Welcome to the Community Forums. Thanks for sharing the details about the issue with your new Versa 2.
Please note the microphone in your watch only turns on when you’re using a feature that requires your voice, such as a voice assistant. The microphone turns off when the voice assistant responds, when you close the voice assistant, or when your watch’s screen turns off.
Fore more information and troubleshooting steps, see: How do I respond to messages with my Fitbit device? and What should I do if my voice assistant doesn't work on my Fitbit smartwatch?
However, you can try these few troubleshooting steps to see if it will fix what you are experiencing:
Hope that helps.
Best Answer07-13-2021 04:58 - edited 01-27-2024 13:23
Hope that helps.
