04-21-2018
07:25
09:50
HeydyF
04-21-2018
07:25
09:50
HeydyF
I have loaded my music onto the versa! However I am unable to turn up or down the volume. It appears as if there are the + - buttons on the right hand side. When I pressed those buttons, nothing happened. Should I try restarting my fitbit? Ultimately I would like to control the volume of the music from the fitbit versa when using my earbuds.
07-09-2021 17:19
07-09-2021 17:19
Hi everyone,
Thank you for sharing your experience with music control on your Versa smartwatch. I appreciate the troubleshooting performed prior to posting.
I see where your disappointment is coming from. I'd like you to make sure you're following these tips to control music on your Fitbit device:
Bluetooth > Restore Music Controls.
As mentioned by others on the forums, to control the volume, you need to tap on the plus or minus icons on the watch itself. Learn more about it in this article How do I control music with my Fitbit device?
This thread will be closed, if needed feel free to create a new post, we'll be happy to jump in.
Hope this helps.
04-23-2018 09:49
04-23-2018 09:49
Hey @kkeogh84, it is nice to see new faces around! If your Fitbit Versa doesn't seem to turn up or down the volume when you press the respective buttons, then I would suggest you to restart it by following the instructions in this post.
In the meantime, you can also control and audio playing music on your phone. Take a look at the following instructions to do so:
Let me know how it goes!
04-28-2018 12:53
04-28-2018 12:53
Thank you for your ideas. I tried these things and no success, yet. I also contacted customer support and they said this is an issue they are aware of with airpods. They are currently working towards fixing this. I wonder if anyone knows when this problem will be resolved so that I know when to restart my versa. Or would I need to download new software onto the versa?
04-30-2018 06:47
04-30-2018 06:47
Thanks for the update my friend @kkeogh84 and for taking the time to contact our Support team for additional help. As they mentioned, the Fitbit device can't control the volume on Apple Airpods, and to be honest with you, I don't know when this will be resolved, so I can't give an estimate time frame for this to be fixed. In the meantime I will ask you to be patient while our team is working on this.
Let me know if you have additional questions!
04-30-2018 07:11
04-30-2018 07:11
I have the Bose Soundsport. After I paired them I had the same problem. I reboot the watch and have worked great since. If you want a Bluetooth headset that you can control the volume you might want to check them out.
05-04-2018 18:04
05-04-2018 18:04
I don't know what the problem is...I have my AirPods on now and can control the volume on my Versa....you will see the plus sign at the top for high volume and there is a negative sign at the bottom right...just keep tapping that and my volume goes down no problem.
05-05-2018 20:16
05-05-2018 20:16
I have tried tapping the + and - signs and it does not work for me. I have also tried shutting down the versa and starting it again, that does not work.
05-15-2018 11:03
05-15-2018 11:03
I have the same issue. I noticed that if I don't have headphones plugged in the volume control works. HELP!
06-15-2018 10:12
06-15-2018 10:12
I have the same problem - when are we going to get a firmware update to fix this?
06-24-2018 12:27
06-24-2018 12:27
I asked right after I got my fitbit versa when this issue would be fixed. I was given no timeline. I'm beginning to feel like the airpod volume issue will never be resolved, as this is clearly not a priority to fitbit. And just for the hey of it, I just tried changing the volume on my airpods while using the fitbit versa and no success. I will probably be looking to purchase a different type of bluetooth earbuds, spending yet more money. I'm just really disappointed because this was the main reason I purchased the fitbit versa.
06-25-2018 09:11
06-25-2018 09:11
Hey guys, @kkeogh84, @Scooter2, @Juleshtown49, @tasha831 and @bitBitbit, thanks for your participation here in the Community! I totally understand how you feel about this inconvenience with the Apple Airpods, but as I've mentioned, I have no updates yet about this, but trust me, our team is working on this and trying to find a solution, and as soon as I have a response, I will share it with in here. In the meantime, I will appreciate your patience and understanding.
Let me know if you have further questions!
07-09-2018 10:43
07-09-2018 10:43
Also experiencing no volume-control ability with my apple airpods...tried all your suggestions.
Totally unacceptable lack of response from Fitbit. This needs to be addressed and solved immediately.
07-12-2018 15:06
07-12-2018 15:06
I agree. Using the Versa with airpods was the primary reason for my purchase.
07-12-2018 15:07
07-12-2018 15:07
Ok, I get that I can't control the volume with airpods, but while you're looking for a fix can you tell me a way to simply increase the volume and leave it there? It's just too quiet to go running with.
07-12-2018 15:38
07-12-2018 15:38
07-12-2018
17:13
12:01
HeydyF
07-12-2018
17:13
12:01
HeydyF
Well, I think that info you reboot both phone and Versa, the pods will play at a preset “medium” volume. But that might not be loud enough
Moderator edit: Format
07-28-2018 07:23
07-28-2018 07:23
update: Just restarted the fitbit, paired the airpods, and no ability to change the volume. I've pretty much given up on the idea that this problem will be fixed and now use a cheap pair of bluetooth earbuds, they work alright.
08-20-2018 14:34
08-20-2018 14:34
Any up date on using Air Pods and controlling the volume while listening to PANDORA? I'd like to cancel my paid subscription to PANDORA if I can't use the VERSA and listing to PANDORA with enough volume while working out. Defeats the reason I bought the VERSA. Kinda disappointed.
09-16-2018 00:10
09-16-2018 00:10
Hi every body
i really upset to say that i turned my versa off & On but my volume control does not work & i do not have Android phone to increase volume
could you please tell me how can i increase volume by Iphones?
09-16-2018 06:33
09-16-2018 06:33
