04-21-2018
07:25
09:50
HeydyF
04-21-2018
07:25
09:50
HeydyF
I have loaded my music onto the versa! However I am unable to turn up or down the volume. It appears as if there are the + - buttons on the right hand side. When I pressed those buttons, nothing happened. Should I try restarting my fitbit? Ultimately I would like to control the volume of the music from the fitbit versa when using my earbuds.
09-16-2018 23:08
09-16-2018 23:08
10-01-2018 12:14
10-01-2018 12:14
Yes I also have the same problem with the AirPods, and I also bought the Versa specifically to have non bulky music at the gym. The volume CANNOT be controlled from the Versa no matter how many times that lady who keeps posting tells us hers work! I also cannot use my expensive Jaybird Runs, with those the left side doesn’t have sound. I have had extensive support from Jaybird with no solution, it is the Versa. Every other device I own works with both the AirPods and the Jaybirds. Frustrated is an understatement!
Best Answer10-03-2018 10:24
10-03-2018 10:24
I have the same problem and am so frustrated. Bought Versa to be able to run with music without my phone- didn't get apple watch because I don't want to be connected when Im running, and now it's like the music is whispering. So annoying and may need to return and swap for something else if there isn't a reasonable fix. I have tried restarting, unpairing again and again with nothing.
Best Answer10-26-2018 07:57
10-26-2018 07:57
It’s now October and there is still no solution to this?? What’s up with that?
11-23-2018 05:44
11-23-2018 05:44
Fitbit clearly does not care to fix this problem!
11-23-2018 19:04
11-23-2018 19:04
I know this isn’t a fix, but what I did to turn the volume up and down on the air pods was connect them to the phone. Once I got the volume where I wanted it I disconnected the air pods from the phone and connected them to the versa. Obviously I rather have them adjusted through the watch, but this is a work around for now.
11-24-2018 00:14
11-24-2018 00:14
11-24-2018 09:53
11-24-2018 09:53
Hey guys! I hope you are having a good day!
I'm afraid my friends that, the Fitbit device, in this case the Versa, can't control the volume on Apple Airpods. In the meantime, please take a look at this idea on our Feature Suggestions board, leave your vote and comments, so other users can do the same and our team can take a look at it. Maybe it can be possible in the future.
Have a nice day!
01-01-2019 12:27
01-01-2019 12:27
Got my Versa last night, just put music on it moments ago and now I come to realize this problem has been persistent for others for months. Not exactly happy about this. What's with the massive delay in resolving this issue?
Best Answer01-02-2019 05:16
01-02-2019 05:16
Hey @MikeH7186, welcome aboard! There is no time-frame for this to be resolved my friend, however, you can take a look at this idea on our Feature Suggestions board, leave your vote and comments so our team can take a look at it and maybe fix it in the future.
Let me know how it goes!
Best Answer01-04-2019 02:30
01-04-2019 02:30
Umm so I got my Fitbit Versa today and I have just downloaded spotify on it and signed in and everything. I paired my Bluetooth headphones to the versa but I can’t make the music play. I keep turning the volume up on my versa and headphones but no sound comes through. It also frequently pauses itself. HELPPPP
Best Answer01-06-2019 19:49
01-06-2019 19:49
When I first started using my AirPods with my versa I also found that you couldn't control the volume using the versa. However I did find that if you pair your AirPods up with your phone and then adjust the volume using your phone, then go back and pair your AirPods with your versa you should notice a change in volume. This is a bit of a pain but I was at least able to adjust the volume so I could enjoy the music while I worked out. I hope this helps.
@kkeogh84 wrote:I have loaded my music onto the versa! However I am unable to turn up or down the volume. It appears as if there are the + - buttons on the right hand side. When I pressed those buttons, nothing happened. Should I try restarting my fitbit? Ultimately I would like to control the volume of the music from the fitbit versa when using my earbuds.
Best Answer01-15-2019 17:42
01-15-2019 17:42
Just so I'm clear. The most popular, best selling bluetooth headphones on the market do not work with Versa because you cant control the volume and there is no solution in sight?
Best Answer01-16-2019 08:24
01-16-2019 08:24
Yes you will have to pair with your phone first and adjust the volume and then pair with versa and check to see that your volume is where you would like it to be. You might have to do this a few times until you get what you want
Best Answer01-19-2019 20:48
01-19-2019 20:48
I have the same problem with my Airpods. The volume buttons on-screen and the physical buttons don't do anything.
22:00
07:36
JuanJoFitbit
01-19-2019
22:00
07:36
JuanJoFitbit
its not working on my watch.
mine too!!!
Moderator edit: merged reply
Best Answer01-22-2019 05:31
01-22-2019 05:31
Hey guys! I hope you are doin' fine! I totally understand you folks, but as I've mentioned, there is no time-frame for this to be resolved yet, so you can take a look at this idea on our Feature Suggestions board, leave your vote and comments so our team can take a look at it and maybe fix it in the future.
I will appreciate your understanding.
Best Answer01-26-2019 20:40 - edited 01-26-2019 20:49
Not being able to change the volume is not acceptable. I paid good money for the Versa (upgraded from the flex) and I specifically picked the versa due to being able to upload music to it. However not being able to change the volume is not acceptable at all. I now regret purchasing it as my songs are playing at a volume that is so loud that someone across the room can hear the headphones (when they are sitting on my desk...as I can't put them on my ears as I would damage my ear drums!).
It does not appear a headphone/headphone brand issue as though I have low-cost ones (Lobkin) others appear to have the same issue with upscale headphones.
Best Answer01-28-2019 06:34
01-28-2019 06:34
Hey @Carleecat, it is great to see you around more often! I'm sorry to hear that you can't change the volume of your headphones through your Versa. I could suggest you to try to restart your Versa, then try to pair your headphones with it again and see if that works.
Best Answer01-28-2019 16:08
01-28-2019 16:08
