10-06-2019 01:10
10-06-2019 01:10
There is no need to register your fitbit and the warranty runs for 12 months from purchase (or 24 months if you are in Europe). There are some conditions though - you can read the full terms at https://www.fitbit.com/in/legal/returns-and-warranty
The first step in a warranty claim is to contact customer support via contact.fitbit.com
Before you do that, is the problem anything that we in the community may be able to help with?
10-06-2019 02:40
10-06-2019 02:40
Are you in the UK? https://www.which.co.uk/consumer-rights/advice/i-want-to-return-my-goods-what-are-my-rights
Your Consumer rights 'what & that you can or cannot do or expect' are listed here:
UK only: https://www.which.co.uk/consumer-rights/regulation/consumer-rights-act
If not in the UK? As @SteveH has already correctly advised ✔
10-06-2019 03:30
10-06-2019 03:30
So if there is not any problem then we didn't have to contact Fitbit care this only applies when you are facing such issues to claim warranty I didn't face such issue right now because I am new to Fitbit and so confirming that claiming warranty is mandatory or not thanks btw
10-06-2019 03:33
10-06-2019 03:33
That's correct - if you don't have an issue then you don't need to do anything.
10-06-2019 03:35
10-06-2019 03:35
Thank you Sir
Best Answer10-06-2019 04:54
10-06-2019 04:54
It doesn’t matter because they don’t really do anything if something goes wrong with your Fitbit! My Fitbit is in the retailer for a month now and I heard nothing back. Contacted the support center and heard nothing back. Posted in the community and heard nothing back.
Bought my Fitbit 8 months ago in Germany and now live in Norway.
