Watch face with heart rate on always on display?
Sometimes my versa doesn’t wake up immediately with the twist of my wrist and i just wanna check my heart rate real quick, is there a watch face that literally just has my heart rate and the time on the always on display?
1 REPLY 1
HI @hadsterman - normally the clock face comes on when you raise your wrist to look at the watch. If you are in Sleep mode though, it won't.
Always On clock faces tend to be minimal to reduce the drain on the battery. If you do find one you may have trouble with the battery life.
One other thing you can do if Sleep is not on, is a sync then a Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on the charger to restart it and charge it.This should remove anything making it sluggish.
