01-29-2020 02:34
01-29-2020 02:34
Hi,
I go the versa 2 at Christmas and everything was ok to being with but the past 2/3 weeks whenever I go for a 5 kilometer run, the Fibit looks as if it is tracking the run but it can come up as anything from 3km to 5km when finished.
Does this happen anyone else? Do you know how I can fix it?
01-29-2020 09:18
01-29-2020 09:18
What phone are you using? Is it on Fitbits fully compatible phone list? If not they'll tell you its the phone fault for the app not reading the GPS correctly and there's nothing they can do.
01-30-2020 05:16
01-30-2020 05:16
01-30-2020 05:56
01-30-2020 05:56
I'm in the same boat. My fitbit tracked perfectly for 12 months, then after the last firmware update its half a mile off over a four mile run. Fitbit support were clueless and basically said its because the phone isn't supported. Still doesn't explain why it worked fine.
