06-18-2022 19:47
06-18-2022 19:47
For some unknown reason, my watch no longer displays when I turn my wrist. I have restarted and turned off and turned on the watch and that makes no difference. For the record it is a Fitbit versa, original.
06-18-2022 20:20
06-18-2022 20:20
This is common. You probably accidentally have 'Screen Wake' set to Manual instead of Auto. If not, you are in Sleep Mode. You can see these both in Quick Settings or the full Settings app on wrist.
06-18-2022 20:20
06-18-2022 20:20
06-19-2022 15:04
06-19-2022 15:04
Thanks. That was exactly what the problem was. I have no idea how I could have turned on manual screen wake.
