12-12-2019 14:52 - last edited on 01-29-2020 09:50 by AlessFitbit
After installing the latest firmware update, whenever I log 8 oz. on my watch, it syncs to my mobile device as 0.27 oz. Moreover, when I log 4 oz. and 12 oz., it syncs as 0.14 oz. and 0.41 oz., respectively. There's definitely a bug in there!
Moderator edit: title for clarity
12-17-2019 09:07
12-17-2019 09:07
I should clarify - when you enter fl oz on your watch, it shows up as the fl oz converted to liters on the app, but still lists the units as fl oz on the app.
Example, 8 fl oz is 0.23 liters, so it rounds it to 0.3 liters, but displays it as 0.3 fl oz in the app.
16 fl oz is 0.47 liters, so it rounds to 0.5 liters, but displays it as 0.5 fl oz in the app.
22 fl oz is 0.65 liters, so it rounds to 0.7 liters, but displays it as 0.7 fl oz in the app.
My Fitbit also randomly adds "8 fl oz" or "16 fl oz" to my log for me, which is either 0.3 liters or 0.5 liters, shown as fl oz in the app.
Needs to be fixed ASAP
12-17-2019 12:54
12-17-2019 12:54
Versa 2 is not logging correctly through watch. If I put I drank 1 cup through watch it says some ridiculously low amount of my app like .03 cups.
12-17-2019 13:48
12-17-2019 13:48
This is extremely frustrating. Having the same issues. Either does record to app but says incorrect amt (32oz appears as 0.1oz on app) or does not log it at all. Just bought the Versa2 Special Edition, and water intake recording was one main feature I wanted in a device. Hoping they resolve this bug in the very near future, otherwise I'm returning mine.
12-17-2019 16:59
12-17-2019 16:59
I’ve updated and restarted my versa 2 watch and it still does not sync the amount of water consumed with the Fitbit app and vice-versa. Water logged on the app doesn’t show up on my watch.
It would also be more useful if the versa 2 watch display showed the total amount recorded cumulatively instead of the last number of ounces recorded and at what time they were recorded. I’d look to see the water tracking display that is on the Fitbit app dashboard be used for the watch display. Having them sync correctly and have the same display would be most helpful.
12-17-2019 19:11
12-17-2019 19:11
What it the status of the fix on the water intake? I am having the same issue as everyone else.
12-18-2019 03:31
12-18-2019 03:31
Hi @AlessFitbit I have done all of the above yesterday, including turning off and restarting both watch and phone and still having sync issues. When I enter 12oz on versa it shows up as 0.4oz on iPhone app. Very frustratin.
12-18-2019 07:18
12-18-2019 07:18
I am also having this issue. The log is a potion of what I enter
12-18-2019 08:22
12-18-2019 08:22
People need to call support and report this. I opened a case yesterday and it was sent to engineering, but important to have lots of tickets opened with support and escalated.
Looks like this is a user community forum, not monitored by support or engineering. so complaining here, while nice to know others are having problems, does not get the info to engineering to get it fixed.
so if you just complaing on the forums the status of the fix will be never because Support and engineering won't know there is a problem to fix.
12-18-2019 09:37
12-18-2019 09:37
When I try to enter water on my watch, I get a message that says Maximum logs entered, sync your device with the Fitbit mobile app to resume logging.
It says this even when I have just synced the phone!
12-18-2019 10:03
12-18-2019 10:03
Hey everyone!
Sorry for the delayed reply. I appreciate the time you took to share the troubleshooting you've tried.
I've merged the posts here because everyone is experiencing the same issue. I truly appreciate your reports regarding this issue, I've shared them with my team and they are looking into your inquiries. As soon as I have more information, I'll make sure to keep everyone updated.
Your understanding while this gets resolved is appreciated. I'll be around if you have any additional questions.
12-18-2019 10:10 - edited 12-18-2019 11:32
Issue: not logging water at all.
1. I am on 70.7.14 firmware.
2. Updated the Today app.
3. Updated the fitbit app.
4. Restarted the watch.
Now it logs the water. Howerver, it is using the incorrect unit.
I log 8 oz and through the watch and it adds point something.
If I add 8 oz in the fitbip phone app it works as expected.
My Solution:
1. Change the units to ml.
2. Forget about the units. It will say 8 ml but I know it to be 8 oz. lol.
12-18-2019 12:00
12-18-2019 12:00
12-18-2019 13:12
12-18-2019 13:12
12-18-2019 14:20
12-18-2019 14:20
just to be clear, this is a firmware bug in the Versa 2 watch, is going to happen to EVERYONE who is using fl oz.
Probably also happening to all the versions of the Versa and probably other devices.
Everyone needs to call or chat with support get the issue logged and make sure that the support technician escalates it to Product Management/engineering.
It only gets logged as a bug from Support
12-18-2019 14:28
12-18-2019 14:28
how can you say this is "Solved" the devices are still broken and will be until a firmware update is pushed out?
12-18-2019 22:36
12-18-2019 22:36
This is exactly what mine is doing. I put in 20oz and it then reads it as 0.7 oz. if I do 591 oz (which like you said is reading as milliliters) it shows 20oz
12-19-2019 10:39
12-19-2019 10:39
Hey everyone! Thank you so much for the details mentioned.
I've escalated this issue to my team and they are aware of it. As a workaround, please delete the entries and re-add them directly to the mobile app.
We’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if you have any other questions.
12-19-2019 12:58
12-19-2019 12:58
This is really frustrating. I got basically the same response from the tech support online. “Sorry about your problem - we’re looking into it (someday).” (My interpretation.) No answer as to why they have let this go on for so long. Based on the posts it looks like this problem has been around for a year or so. There was no sense of urgency to resolve this issue. I’m starting to wish I didn’t buy this thing. I only upgraded because of the sale. I’m really disappointed in their customer service and tech support.
12-19-2019 13:32 - edited 12-20-2019 14:18
☹️ when is the next firmware release?
12-19-2019 14:21
12-19-2019 14:21
I am having the same issue with entering water as ounces, which then logs in as millimeters. Also, the Weight entries are wrong. when I enter 225 pounds on the watch, it registers as 496 pounds on the app. I had the Fitbit for a week.
