08-15-2021 12:24
08-15-2021 12:24
Just come off chat with one of your advisors who cut me off short when things got a bit difficult, you will see this from the times and the unsatisfactory answers he was giving. My next comment was going to ask if I'm surely covered by the consumer protection act since I was sold a product with an in built defect, as your advisors says it does not just become not waterproof after the warranty has ended. I've had nothing but issues with the Versa, this being the 2nd one which has battery issues a d is now dead due to water ingress, and yes I can see the water droplets in the rear sensor, thus making the watch a danger if charged.
I tried to upload an image of the chat but am unable to do so.
08-15-2021 12:33
08-15-2021 12:33
Heres a copy of the transcript, 42 seconds wasnt quite long enough for me to type my next comment after being asked for one:
11:36:35 System: Thanks for waiting. Please provide as many details as you can so we can get you back on track.
11:37:53 Agent: Joel Angelo L.: For me to better assist you, may I know more details about your concern?
11:37:58 Jayne (.: Hi I have a fitbit Versa special edition, I emailed before about a better problem as it
11:38:33 Jayne (.: Doesn't last 12 hours from a full charge
11:39:00 Agent: Joel Angelo L.: Thanks for this detailed information.
11:39:16 Jayne (.: *battery
11:39:17 Agent: Joel Angelo L.: Let me help you with the Versa's battery that is draining quickly.
11:39:34 Jayne (.: That is noo ger the only problem
11:39:50 Jayne (.: *no longer
11:40:03 Agent: Joel Angelo L.: Okay.
11:41:26 Agent: Joel Angelo L.: May I know more specific for the other problems having with your Versa?
11:42:24 Jayne (.: I was offered a 35% discount as it was already a replacement for a previous one that failed. Now the watch does not work at all as I can see it has water ingress, it is completely lifeless and does not charge.
11:42:53 Jayne (.: As this would be a manufacturing de
11:43:23 Jayne (.: Defect could it be replaced?
11:43:54 Agent: Joel Angelo L.: Thanks for this.
11:44:47 Agent: Joel Angelo L.: I would like to inform you that the discount has been already generated with the Versa device.
11:46:12 Jayne (.: I'm not looking for a discount, there is something inherently wrong with the device for it to leak, why would I pay for that?
11:46:29 Agent: Joel Angelo L.: The Versa is already beyond our warranty period which why we offered a discount that you may take advantage in purchasing a new one.
11:47:07 Jayne (.: I have both Versa bodies I am more than happy for you to have them back and you can
11:47:11 Agent: Joel Angelo L.: Before the issue about the leakage the device has been found out that it was already defective.
11:47:22 Jayne (.: See that it has a manufacturing defect
11:47:52 Jayne (.: And now the same device is twice defective
11:48:17 Jayne (.: And you've also agreed that it is defective
11:48:51 Agent: Joel Angelo L.: Yes.
11:49:20 Agent: Joel Angelo L.: And I'm trying to explain that the Versa is already out of our warranty period.
11:50:14 Jayne (.: Yes I understand but it is not fit for purpose, are you saying that it is only waterproof for a year?
11:51:33 Agent: Joel Angelo L.: All our products are made to be last.
11:52:10 Jayne (.: This one hasn't along with multiple others reported with water ingress on your forums
11:52:30 Agent: Joel Angelo L.: I apologize fort this matter that has caused you.
11:52:41 Agent: Joel Angelo L.: We are constantly improving and upgrading our products to deliver the best to our customers.
11:52:53 Jayne (.: Do you want me to send it back so you can examine it
11:53:23 Agent: Joel Angelo L.: I appreciate it but we do not have a repair service nor program for examination.
11:55:06 Jayne (.: This watch has a defect that was not intended, it could prove dangerous when charged due to the water ingress
11:55:46 Agent: Joel Angelo L.: Do not use or change anymore the Versa device as that was already found to be defective.
11:56:03 Agent: Joel Angelo L.: You may recycle it through a recycling program near you.
11:56:32 Jayne (.: You bear some liability in this instance and therefore should replace it
11:57:12 Agent: Joel Angelo L.: Our warranty policy covered defective device within our warranty period.
11:57:28 Agent: Joel Angelo L.: Your case is no longer covered by the replacement under our warranty.
11:58:02 Agent: Joel Angelo L.: By the way, you’ll receive a quick customer satisfaction survey after this chat. We appreciate any comments.
11:58:16 Agent: Joel Angelo L.: While we are still connected, would there be anything else I can help you with?
11:58:58 Agent: Joel Angelo L.: I will now release this chat, please reopen a new chat or visit Fitbit.com (help.fitbit.com). Thank you for contacting Fitbit.
11:59:00 System: The chat is ended.
11:59:01 System: Joel Angelo L. left the chat.
