01-24-2019 09:54 - edited 12-18-2019 13:16
Fitbit Update: 12/18/19
Hi everyone,
When this thread started earlier this year, the issue was that waterlogging on the watch was not syncing over to the Fitbit app. No matter what you would log, it just wouldn't show up in the Fitbit app and didn't sync the information over.
Now, we're seeing reports that waterlogging is syncing over, but it is the wrong amount of water that was logged onto the watch. To keep threads organized and on-topic, I'm now going to close this thread and move the conversation here: Water Logging syncs incorrect amount to app.I've already merged some posts from this thread into that one.
If you're experiencing this new issue after updating to Fitbit OS 4.1, follow that thread for updates.
Fitbit Update: 2/7/19
Hi everyone!
Thanks so much for your patience while our team continues to investigate these reports with water logging issues. If you haven't yet tried some troubleshooting steps, I'd recommend the following:
I'll keep you updated, so please stay tuned!
Fitbit Update: 1/24/19
Hey Versa Fam!
Our team is still investigating these reports for water logs not syncing over to the Fitbit app after logging them on your watch. We appreciate your reports and feedback.
If I receive any new information, I will update this thread so please stay subscribed. Thank you!
Best Answer03-06-2019 14:45
03-06-2019 14:45
I know and I am sorry!! For me I just accepted the fact it's my watch nothing more Again even though it is not my fault I am sorry for everyone who had to waste so much money on a product that isn't worth it
Best Answer03-06-2019 15:31
03-06-2019 15:31
you are absolutely 100% correct, no matter what the moderators say that they are working on it. They are not. They just came out today with a Fitbit versa light version. They really should fix the original version of the versa before they go introducing new versions.
03-06-2019 15:47
03-06-2019 15:47
Most Definitely!! The new watch that came out is their primary focus. Then it will be on to the next, and the next They probably copy and paste their responses to all of us This problem among gobs of other issues have been going on for way over a year with the very same responses It's truly tragic.
03-06-2019 19:07
03-06-2019 19:07
My FitBit Versa still has this issue. I have an iPhone 7 Plus. The Versa has all sorts of syncing issues. It doesn’t seem able to show that day’s workouts, even though I manually activate them on the Versa. And if I enter my water intake on my Versa it doesn’t show up on the app ... or it suddenly shows up, but on the wrong day — so it will look like 130 ounces on one day, and zero on another. I’m constantly having to guess, do complicated math, input data multiple times, etc. I “upgraded” to a Versa from my Charge 2 for all of these extra features ... but none seem to work properly. I should have taken the free Charge 2 warrant replacement instead of paying more than $100 for something that doesn’t do what it is supposed to do.
Best Answer03-07-2019 01:02
03-07-2019 01:02
Hey guys my advice is to return it to fitbit for a full refund. They advertised the products with this feature and it doesn't work so breaking UK (I'm not sure in other countries) Trading Standards law (you can't advertise and sell something that doesn't work 100%) - you're entitled to a full refund.
Fitbit if you're listening - sack your head of development. Instead of putting resource into new features, fix the old features that don't work first - otherwise you're just gonna p*ss off your customers and they all tell they're friends how crap it is and it's not fixed. There's 3 in my office alone that want to buy a versa but aren't because they really liked being able to log water intake during the day on the fitbit.
No excuses Fitbit somebody isn't delegating and prioritising correctly within your company.
03-07-2019 04:07
03-07-2019 04:07
I'll except it for now but won't be purchasing another fitbit device in the future.
03-07-2019 06:44
03-07-2019 06:44
Did this but didn't work. My Today app is updated, I logged in and out in my fitbit app and synced. I even stopped using 3rd party clock because I was told when I contacted the tech support that they are buggy and can interfere with versa's functionality. I am ok with not logging my water in my watch but just like anyone else, the uselessness of this feature is difficult to ignore. Why add it if it's not working or not fully tested?
03-07-2019 14:09
03-07-2019 14:09
Noticed there was an update to the "Today" app on my Ionic. After completing the update, water synced correctly for a day. I was happy as the solution to this long-awaiting problem finally arrived...
The following day, back to the same broken functionality. Restarting the device seems to temporarily fix it, but this is unacceptable if it's something that has to be done daily in order to function properly.
Disappointed to say the least.
Best Answer03-07-2019 17:15
03-07-2019 17:15
Best Answer03-08-2019 06:20
03-08-2019 06:20
ANy update on this? It's March 8th?? I've noticed the same with my brand new Fitbit...the water isn't logging.
Best Answer03-08-2019 07:51
03-08-2019 07:51
Best Answer03-08-2019 12:33
03-08-2019 12:33
Update: I factory reset my versa and did not use 3rd party clocks. The water log synced to the app but I have to tap the water log in the app to update. I have been doing the experiment for a day now. I log the water in my watch, sync, then enter (or access) the water log in the app. It is now flawless syncing like the core stats but it's better while we await the fix.
03-08-2019 12:54 - edited 03-08-2019 12:55
Hello guys, I hope you are doing fine.
I appreciate all the efforts in trying to fix this water log issue by yourselves. Keep in mind that we have a set of Community Guidelines to follow in order to maintain a positive environment here. Please make sure to follow them.
@Karona218, @SunsetRunner, @CubbieGirl21, @RobIgoUK, @Bdeck3, @Cajonat, as mentioned previously, our team is aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track. In the meantime, you can try the instructions provided by our friend @YojanaFitbit here.
@kostax, @blessedgirl1973, @Champaign and @Fitlark, those are great news. I am glad to hear that this feature is working for you and thanks for sharing the steps you tried. If there is anything else we can help you with, do not hesitate to post it.
See you around. ![]()
03-08-2019 22:20 - last edited on 09-27-2019 12:05 by LiliyaFitbit
How do I stop getting these blumin emails I’m getting loads everyday.
Kind regards
Best Answer03-09-2019 06:36
03-09-2019 06:36
Hello @Pickles77, I hope you're doing well, it's nice to see you around the Fitbit Community. ![]()
I appreciate your participation in the Forums and for posting your question. If you'd like to stop receiving updates from this thread as emails, please go to the top of the page and click on the gear icon, then click on "unsubscribe".
I hope this can be helpful. Happy stepping!
Best Answer03-09-2019 12:29
03-09-2019 12:29
23:02
10:33
AlvaroFitbit
03-09-2019
23:02
10:33
AlvaroFitbit
I am also experiencing the same issue. No matter how much I log water intake on the versa it NEVER syncs with my Fitbit app!!!!
Moderator edit: format
Best Answer03-10-2019 08:50
03-10-2019 08:50
Bug fixes need to happen faster than this. This was first reported back in December. It's now March 10th and this feature STILL does not work. Sorry Fitbit, but I will not buy another device. Once I find a suitable replacement for my Versa, I am moving on and not coming back.
03-10-2019 15:02
03-10-2019 15:02
Best Answer03-11-2019 10:33 - edited 03-11-2019 10:35
You didn't read my full post. Below was my original message. Genuinely curious - does the water intake function work correctly for any users posting in this thread? Or is it "broken" for everyone? If it's broken for everyone, why is it advertised as a feature?
