04-10-2018
09:17
08:13
AlvaroFitbit
04-10-2018
09:17
08:13
AlvaroFitbit
My weather app is only working when I am synced and connected to the fitbit app on my phone. Does this app not work over wifi? Any help would be appreciated, thanks!
02-08-2019 09:14
02-08-2019 09:14
Thank you!!!! This worked for me after trying everything else. This also fixed the issue with the weather note showing in my watch face. Everyone should try this for both issues, I hope it works for y'all!
02-08-2019 12:15
02-08-2019 12:15
Having to sync an app on Versa to get anything on your phone is pointless and a worthless feature... Just use your phone!!! Sarcasm is high...
Best Answer02-08-2019 12:18 - edited 02-08-2019 12:22
Having to sync an app on Versa (with your phone) to get any feature on your Versa updated is pointless and a worthless feature... Just use your phone!!!
Best Answer02-08-2019 23:58
02-08-2019 23:58
Best Answer02-09-2019 03:22
02-09-2019 03:22
Best Answer05-10-2019 18:05
05-10-2019 18:05
I had the weather app working for a few days now it does not work. It has the name of my town, says to sync but still does not work. reset and made sure wifi was connected. Using computer and fitbit app . Any other ideas
Best Answer05-10-2019 18:07
05-10-2019 18:07
Did not work!!
Best Answer05-10-2019 18:09
05-10-2019 18:09
Best Answer05-10-2019 20:15
05-10-2019 20:15
Best Answer05-10-2019 20:20
05-10-2019 20:20
Best Answer05-11-2019 13:30
05-11-2019 13:30
Best Answer05-11-2019 13:45
05-11-2019 13:45
Best Answer05-28-2019 03:22
05-28-2019 03:22
My weather app wasn’t working so searched on this forum. Combined all given tips and solutions. So I got it to work again by unchecking all permissions to fitbit app on iPhone. Then deleted fitbit app and reinstalled. Checked all the permissions back on and just in case restarted my Versa. Dunno which one did it, but it works \o/ \o/ \o/
Best Answer05-28-2019 04:10
05-28-2019 04:10
Best Answer05-28-2019 10:01
05-28-2019 10:01
Best Answer07-02-2019 06:20
07-02-2019 06:20
My Weather App is not working. My Fitbit says "Sync the Fitbit mobile app to update." I've Synced several times and nothing happens. Help!
Best Answer07-03-2019 06:58
07-03-2019 06:58
Tried syncing with app open. Still not working. Blaze says "Sync the Fitbit mobile app to update. Nothing happens. Help!
Best Answer07-31-2019 15:33
07-31-2019 15:33
Aha! This worked! Thanks!
Best Answer10-01-2019 07:50
10-01-2019 07:50
No that didn’t do a thing. Versa seems to be way more trouble than it’s worth.
Best Answer10-27-2019 21:05
10-27-2019 21:05
I have a versa lite and I have the same problem. It used to work but now it won't sync the weather. Everything else updates OK. I've recently installed IOS 13 on my iPhone and thought that might be the problem so I deleted the Fitbit app and reinstalled it. Unfortunately it didn't fix the problem
