04-10-2018
09:17
08:13
AlvaroFitbit
04-10-2018
09:17
08:13
AlvaroFitbit
My weather app is only working when I am synced and connected to the fitbit app on my phone. Does this app not work over wifi? Any help would be appreciated, thanks!
12-26-2018 13:32
12-26-2018 13:32
Sorry, I tried your solution as I am using a Samsung Galaxy Note 4 and it did not resolve the issue. Everything worked fine until the latest update a few days ago. the Weather app is not updating to correct temperature.
12-26-2018 21:18
12-26-2018 21:18
FINALLY!!! I tried everything nd your solution worked for me!!! Funny I now remember getting a notification that the Fitbit app was using my location in the background and asked me if I wanted to continue to alllow it and I switched it to “whole using app only” and that’s what goofed it all up! THANK YOU THANK YOU THANK YOU!!!
12-27-2018
14:23
09:02
AlvaroFitbit
12-27-2018
14:23
09:02
AlvaroFitbit
Where did you make the settings change? I have searched and searched and
cannot find where the location change can be made. I am using a Galaxy
note4 android phone.
Moderator edit: removed personal information
Best Answer12-27-2018 14:43
12-27-2018 14:43
Best Answer01-02-2019 10:03
01-02-2019 10:03
My weather app is still not working. Worked fine for a week. The Fitbit is sync’d. Just not the weather app.
01-02-2019 10:56
01-02-2019 10:56
Best Answer01-02-2019 21:10
01-02-2019 21:10
nope weather app on versa not working, any other suggestions
01-02-2019 21:18
01-02-2019 21:18
Best Answer01-02-2019 21:30
01-02-2019 21:30
Best Answer01-02-2019 23:28
01-02-2019 23:28
Hi I have tried following the solution given but My weather app is still not working.
01-03-2019 14:09
01-03-2019 14:09
01-04-2019 15:40
01-04-2019 15:40
Go to the weather settings on the phone Fitbit app...
Best Answer01-12-2019 08:19
01-12-2019 08:19
I am having the same problem with watch faces and the weather. I’ve tried several different faces with weather and non of them work!
Best Answer01-13-2019 01:09
01-13-2019 01:09
Best Answer01-16-2019 08:13
01-16-2019 08:13
The problem I'm having is that I have to constantly sync my Versa and phone to see the weather. I have "All-Day Sync" enabled and inside the Weather app, I have the "Toggle All" enabled to allow Internet, Location and Run in Background" ON. Why in the world when I sit at my desk not 2 feet from my iphone do I have to actually open the Fitbit app and Sync to have the weather show on my Versa? This is the most useless app I have.
Best Answer02-01-2019 13:08
02-01-2019 13:08
15:22
08:56
AlvaroFitbit
02-01-2019
15:22
08:56
AlvaroFitbit
Thank you for your reply. It fixed itself.
Best Answer02-03-2019 09:03
02-03-2019 09:03
Hello everyone sorry to hear that some of you are still having issues with your weather app. I suggest you refresh the link between your phone and your Versa by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Also really important that you enable the Keep Widget alive option on your Versa settings so these apps update in the background. @beckymo1
To change the settings go to the weather app and select the unit you wish for it (Celsius or Fahrenheit)
@vcrkawduc happy to hear that the app is working for you.
@DeeeDeee thank you so much for your help in this thread.
Let me know how it goes!
Best Answer02-04-2019 04:57 - last edited on 10-02-2019 13:54 by LiliyaFitbit
Thank you it worked.
Thanks
Sent from Galaxy S9 smartphone
Best Answer02-04-2019 12:59
02-04-2019 12:59
