12-28-2021
12:56
20:43
12-28-2021
12:56
20:43
Hello All. I'm from the USA and I got a Fitbit Versa 3 from my wife for Christmas. Now Fitbits mostly easy to set up but sometimes you just come across something that won't change, my was the weather units. Since I got my Versa 3 weather showed in Celsius, not Fahrenheit. So I wanted to change it. I search thru forums, and other online resources but none of the processes or steps worked. So my wife took a few minutes playing around with the app on my phone and figured it out. Here below are the steps she took to change the unit display of the weather app on my Fitbit Versa 3.
#1: After opening the App click the Account Icon in the upper left corner. (This could be a picture you set up of yourself or a head icon in looks)
#2: Look for the "Versa 3" icon and lick it. (It's not in the App Settings to change weather apps units of measure)
#3: Now on the Versa 3 page you should see 6 squares with stuff like "Voice Assistant, Gallery, Ect..." Click Gallery.
#4: This is where the apps that are on the Versa 3 are located. Now scroll down till you find the "Weather" app and Click it.
#5: In the Weather app Click Settings.
#6: In this menu Click Units.
#7: Here is where you set your preferred temperature Units by Clicking either Celsius or Fahrenheit.
I hope this helps out everyone. Like I said I searched and found lots of information on different Fitbits but none really were or worked on the Versa 3. When I find out other things that are useful I will try to make sure to post them here if no one else has.
Thanks for taking the time to read this.
12-28-2021 13:00
12-28-2021 13:00
I forgot 1 "LAST" Step.
#8: Once you've selected your unit of measure click Done.
12-28-2021 22:08
12-28-2021 22:08
Hi @GreatTaz - You didn't find this post? How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3. There is a vital last step of removing cities to ensure it works.
Best Answer01-03-2022 17:38
01-03-2022 17:38
Thanks so much. I had tried to just try checking the App settings and ensuring that Fahrenheit was checked. When I used your method, I found that Celsius was selected in Units in the Gallery section and as soon as I corrected that and clicked Done and sync now, problem solved. Cheers!!!
05-04-2022 11:50
05-04-2022 11:50
I really want to thank you very much for listing the "Correct" way to change the weather indicator on the Versa 3!
My day has been made, thank you so much!!
